I kept saying the tabs will bolt the vband part of the CHRA into the housing! lol
tisk tisk tisk why didnt you at least try man lol... still in the plastic and just trying to eye how it fits. you disappoint me good sir.
the vband ring in the packet is for the dump :) maybe thats why your confused lol
yeah with the 06ll2-20g on the rb25 the egt is getting too hot on 98 as the rear is really too small to for rb25 even with the 10cm. The e85 cheats and allows you to stretch it legs abit.
is that due to the fact the 20g pumps hotter air than the 25g? coz simon and others seem to fair perfectly fine with the T67 25g...... despite having the same turbine wheel
I don't get this "pumps hotter air" that I am reading in threads lately. Where is it coming from?
You spin the same turbo harder for more boost and you will often get higher inlet temps courtesy of compressing the air. The intercooler's job is to remove that heat, which whilst isnt 100% efficient ...will remove the bulk of the higher temps if sized correctly. By the time you add fuel, compress and ignite it I cant see the inlet temps having a dramatic impact on the exhaust temps...it will affect the hp but surely it is negligible with regards to EGT
Then you have the hot side and EGT. They can be higher due to the A/F you are running, the cam and ignition timing etc. Oor higher due to exhaust back pressure in the turbine housing or exhaust system as a whole.
So unless you all go and plumb EGT sensors into your dump pipe with a pressure sensor in the scroll of the turbo then I dont think anyone can comment on whether somehting is fine or not as we dont know the numbers. I know on my old 20G setup with a 10cm housing that the pressure readings I was getting suggested that the housing was too big. My 8cm housing doesnt have a tapping for a pressure gauge so have never measured it...though my TD05-18G 8cm housing does so will be measuring it when I am playing with that setup
<p><span style="font-family:arial,helvetica,sans-serif;"><span style="font-size: 14px;">
<br />
I don't get this "pumps hotter air" that I am reading in threads lately. Where is it coming from?<br />
<br />
You spin the same turbo harder for more boost and you will often get higher inlet temps courtesy of compressing the air. The intercooler's job is to remove that heat, which whilst isnt 100% efficient ...will remove the bulk of the higher temps if sized correctly. By the time you add fuel, compress and ignite it I cant see the inlet temps having a dramatic impact on the exhaust temps...it will affect the hp but surely it is negligible with regards to EGT<br />
<br />
Then you have the hot side and EGT. They can be higher due to the A/F you are running, the cam and ignition timing etc. Oor higher due to exhaust back pressure in the turbine housing or exhaust system as a whole.<br />
<br />
True i think we all may be talking different things.
The problems i keep reffering too with the L2 and some of the other prototypes we see come through are related to backpressure (exh valve to turbo). If we compare SR20 with l2 to rb25 with l2 and assume the exhaust system without turbo (headers, turbine, downpipe, etc.) is the same between both motors we can assume the "base" backpressure will be roughly the same.
If theroetically the backpressure measures at 48psi between the motor and turbine. The 2500cc motor will run into a bottleneck because there is 48psi in the exhaust and only 10psi in the intake (a 4.8:1 ratio). This high ratio keeps the cylinder from scavenging/filling fully and therefore limits power. The 2000cc motor, on the other hand, has 32psi of boost (only a 1.5:1 ratio) to push against the backpressure. Therefore it is able to be much more efficient under these conditions.
The bottom line is, as your motor size increases, your boost level will go down (in order to achieve the same power level). In such a case you will need to maximize the flow potential of your compressor and minimize the restriction of your header system (including the turbine) in order to reach your power goals.
L2-20g is so restrictive on the 25 its is hard to control the heat due on 98 in part to the high ratio of boost to backpressure, therefore we need to run lower boost levels to keep the ratio in check and keep det at bay (diluted charge). E85 allows a more efficientsetup would allow as the diluted charge is still more potent..
We have tested exhaust pressure on a few turbos lately and the ratio of boost to backpressure is way to high, its mostly on guys trying to chase respone via small hot sides on their turbos...
ive found to make good power, generally turboed engine efficiency depends more on low exhaust backpressure than tricks with the cams etc and going too small on the hot side of a turbo and you won鈥檛 be able to effectively control EGT鈥檚 no matter what.
If you want to monitor heat trends an accurate ir gun will suffice to see trends in temps but a bung is the way to go for real results.
Its hard to control heat at what point, 18psi-22psi where?
cause I have been thinking for a while now to run e85 and low boost for a healthy 280-300..
Is this going to work or should I cut my losses here and just ditch it for a T67 comp
we can make more power on less boost. E85 will help out.
But when you factor in the power people are making , you are asking the lil 20G wheel to flow around 590cfm or 42lbs ...if you look at the compressor map thats right at the end of its efficiency. Sure the E85 will help it along....but a turbo can only flow so much air. So the whole more power at less boost? If you are already making 280rwkws, by more power do you mean 5-10rwkws at 2 or sp psi less???
Guess it's application dependant really too
Doris running hard on the limiter it might be a struggle with heat..
I drive like a little old lady in comparison so it won't as much an issue and maybe is worth the sacrifice for low down response and possibly/hopefully a punchier midrange :D
around 300max @ less boost generally.
thanx for the explanation there btw .While i get the basic principle here, any chance you could elaborate on how you get these backpressure figures...or are they just derived from testing..
if you have 48psi and 10psi intake, then double the intake to 20psi is that going to double the backpressure pre turbine as well, and how come the 2L has 32psi of boost?
I have been looking at buying one of these turbos, but it seams they are not water cooled. Is this correct? Any real disadvantage to this?
This is the one I'm looking at http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-Anti-Surge-T67-25G-T3-10-cm-V-Band-Housing-/290714087600?pt=AU_Car_Parts_Accessories&hash=item43afe8f0b0#ht_2379wt_1396
Target is 450hp with a little room for more when a 3L goes in.
You can get a water cooler variant, it will be badged as a TD06SL2 25G
as long as it has the 4" cover and the T3 10cm V band rear it will be the same item with a different CHRA.
However, the water cooled version has the normal TD06 shaft (thinner) and the oil cooled T67 version uses a TD07 shaft (thicker and stronger)
There doesnt seem to be a disadvantage to the T67 mang, but whats wrong with your HG?
we had a period of time when some of the proto turbos coming through would take 8 -10 degrees less timing so we used the egt port in the housing to measure EGT and Pressure (thie pic attached is not mine) to determine exactly what was going on in there pressure wise.
thanx for the explanation there btw .While i get the basic principle here, any chance you could elaborate on how you get these backpressure figures...or are they just derived from testing.. if you have 48psi and 10psi intake, then double the intake to 20psi is that going to double the backpressure pre turbine as well, and how come the 2L has 32psi of boost?
Ratio works as follows as we work back from the large engine will small turbo scenario.
48psi in exh manifold and only 10psi in inlet manifold works out to a ratio of 4.8:1 in theory if we were to try and get the same 48psi of back pressure in the exhaust manifold on the 2l we would need to have 32psi on the intake based on the 1.5:1 ratio (derived from testing).
Noting is wrong with the hypergear turbo it still works perfectly. I have upgraded to a top mount manifold and Tial WG so the whole setup has changed. I need a new rear housing for the ExGate.
I can sell the turbo to a friend(Including dump oil lines intake pipes 3 actuators) buy a new one and have some cash left over to go towards making a new dump
I was looking at getting Hypergears gt35r equivilent but have not seen any proven results.
Really just weighing up the options i have
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
