heres my entry form, just qualifies :laugh:
RED..pulp @ 15psi (E85 @ 15psi made 288kw)
BLUE...17.5 psi on E85
GREEN..21.5 psi on E85
As you can see the extra psi stopped making enough difference to be worthwhile. 18psi is about where I wanted to be anyway so its worked out good..
The torque increase through the midrange on E85 is brilliant, makes it so much more driveable in regular traffic situations..and after 20min or so driving around I opened the bonnet to find a very cool motor..
Anyway its no T67 but it is very nice and responsive to drive, with more than enough power to get me into trouble..
Should keep me satisfied for a while.. :) good diff and tyres on the want list now..
What turbo is that
What turbo is that? looks almost identical to my graph.
Realistically it doesnt matter if u get the 3" or the 2.4"...... But if u go the 2.4" ull be able to use the stock intake pipe for teh epic stealth ;) just need to make a heatshield to cover the gate.
If I had an RB20 powered car I would probably do the exact setup we are talking about. Stock manifolds, TD05H 18G with a gate off the housing. Stealthed up and stock position. Like I said 230-240kw and it would be pretty responsive/solid. Ive recently done a TD05H 18G SR20DE and that is a weapon. Faster than a 260rwkw 3076R SR20DET (both S13s).
can u fit the td05 in the stock turbo position?
and ive got one of those china split dump screamers (havnt used it yet) could i just run an internal gate td05 with this so i dont even need a wastegate?
well I dropped mine off for tuning today. Bit of let down really but nothing super bad. Turns out my AFM is too close to the turbo and is causing it to be a pain the ass. The real issue was that it was spiking uncontrollably. ASG told me to change how the waste gate merges with the collector on the manifold. Does any 1 have any input on how it should be changed. The manifold is 1 of the NZ steel 1's from the other thread. and the gate is a Compgate 40.
Chris
I'm running stock cam gears still and stock airbox..that could be worth couple hundred rpm lag..either way it is what is and should keep me content for a while..If I get bored a simple 25g + manifold conversion could net me 100kw extra.But for now, she'll be right..
LOL, for what its worth i run a dirty old HKS filter in my engine bay with no shielding just a duct to it :whistling: I am going back to std airbox so I hope it isnt going to hurt power
Yeh, I am betting its the length of pipe before the manifold. Some people have problems with the 6boost having boost creep when they plumb the gate down near the steering rack rather than high up near the collector. Thats the reason I got rid of my Trust Type R gate as it was too large to package near the collector.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
