It also stops if I turn the car off turn turn it back on again..Aside from turbo and cooler whole setup is stock standard..Actually just thinking, I did pull the restrictor out of my boost gauge line, this couldn't do it could it
Will do :cheers:
I know he spent a bit of time sorting the cold start so what are the chances it would be fine without the AAC anyway.. I always warm it up before I drive, I don't have aircon and I'm sure there is enough power to run the PS.. So what is it good for really ?
Will do :cheers:
PS does put a lot of load on the engine though, mine used to stall with the NIStune when I turned the wheel at idle.
But the PS switch should allow for that, pretty sure i swapped a few back in my Falcadore mechanics days..... Assume skylines would be similar?
Yeh, but if you didn't have the IAC valve, how would the ECU raise the idle?
I usually try to avoid turning wheel at idle anyway, on any car..drive an old car with np PS and you learn pretty quick to only turn the wheel when car is in motion ;)
Yeh I try to do the same, but to get my front bumper off I have to turn the wheels. I just think it's rather inconvenient NOT being able to, even if I usually avoid it.
just wondering..ive never seen the td05 come in 25g, i was going to go for a 18g but would i see any benefits with the 25g on the rb20?
maybe holds boost longer? longer spool time? so on
http://www.ebay.com.au/itm/Turbo-Turbocharger-Hybrid-TD05H-25G-AR60-8cm-T3-Turbine-V-Band-4-inch-Cover-/110859057273?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19cfb6f879#ht_2063wt_855
Edited by RBert
TD05H 25G is not something you should go for. The 25G wheel can flow upward of 500HP, the TD05H wheel is stretched at best to be nearing 400HP.
Even a TD05H 20G is a touch of a mismatch, and can often run into surge issues.
FYI the different between an 18G and a 20G is the inducer size. Sort of like comparing a 3076R in 52 trim and 56 trim. Going the smaller will trade a little bit of top end for some spool. In this case both wheels have a 68mm OD but the 18G is a better overall match to the TD05H.
The best way to get a grasp of whats a good combo or not is what Trust have developed and sold as their own kits. In this case either pick the TD05H 18G or the TD06SL2 20G...... One for better low end and midrange, the other for higher end power and midrange. 240 and 260kw respectively.
okay thanks for that, back to the td05 18g then, but is there a way around the drop in power higher in the rev range?
also if i go td06 for more power how much do people usually loose low down as in spool time so on?
So I was just browsing kandos on ebay again and noticed that all TD06sl2 t3 10cm turbos come with anti surge covers now...
Whats going on there??
I haven't noticed any surge issues apart form the huge surge of power when i put the foot down :P
haha tama easier said than done :P having 350 with the td06 is all well and good but i don't want to wait an extra 500-1000rpm for it. td05 for the street and a few track days will make me more than happy.
You wont feel it losing power up top mate. It will haul to redline.
Only difference is how much of the peak power is made and how much spool time is lost.
The TD05 is likely to be quite lively between 3 and 4k RPM with a little more meat than the TD06 from 2 - 3 aswell. The TD06 will probably be very flat from 2 - 3 and get a fairly abrupt rush of power around the 4k mark. Like I said, TD05 will probably go 240kw and TD06 will probably go 260.
This is all provided you set it up right.
I found by applying the KISS theory these were the results I got
Rb20
drifting or hard track = tdo6-20g
street with occasional track = td05-18g
Rb25
drifting or hard track = t67-25g
Street with occasional track = td06-20g
Now there is no doubt other options outside of this but quite frankly, if you can't figure them out by yourself, well your probably punching above your weight... Anyway so what's the verdict on the SL2 fellas..seems it shapes ok to an old HG or a 3071..but is it any better or worse, cause all in all the setup is almost as expensive..
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
