the way i worked it out was its probably revving to about 7000, maybe a bit less like most ppl do...
the graph doesnt show RPM but it does show rod speed.. so if 180kmh is close to 7000, 90kmh is close to 3500.
its a few rpm off but close enough, boost is definitely well and truly on before 4000. a good achievement.
no way 3500 is 90km :no:
Anyway out of curiosity and boredom I just laid my dyno sheet next to battery's..
Im sure many of you have done this already.. but im posting it.. :D
Not alot in it really, they are running almost identical boost , I have a fair bit more midrange torque and an extra 20kws at 5k, but nose over after 6k where they are both pulling 300kws,
Then he keeps pulling past 7 and smashes me..
Just remembering though I have alot less mods under the bonnet <<read excuse for losing... :Pbatterydynosheet.jpgtune300.jpg
Im not gunna bother comparing anything to Simons freak of nature....
well know how many revs it is if we know where the run ends.. speed and RPM are always relative. you will do double the speed at double the revs in the same gear etc.
nice comparo too :) i cant wait to pop a 20G on my SR
Aaww don't be sad Simon you know your my hero.
Its more the fact I can't be bothered converting all your dynosheet figures to something legible. :laugh:
I think u were making the same as me at 5Ooorpm
On low boost mine is about the same as yours at 5000rpm, high boost close to 30kw more
You guys need to screw more boost in... 2bar or bust :)
Edited by SimonR32
Yeah you can see my 20g making more on the green line but that was 21.5 psi which is 4psi more than the blue line and the gains were insignificant..As Roy said the little comp just can't push any harder ,its giving all she can give..especially on my setup..If I get a better manifold and plazmaman plenum and better cooler it could possibly push for a little more.. But looking at the comparison I would sooner just get a T67 than push this any further.
Not sure why battery didn't push more in..
Got a scanner Artz? I think I could use my broken ass Photoshop skills to overlay onto the same image..
Just re did all my cooler piping in 2.5"(was a mix of 2.25/2.5" before) and now i'm thinking maybe I should move to a bigger Throttle body, not sure if there is much point cause the stock one is still bigger than the 2.5" piping ??
Haha I was putting mine over a picture of yours on the computer, I was gunna trace it but gave up..its almost identical though with yours just dipping a Little between 4-6rpm
That's the same size as my cooler piping I guess there is hope for it yet :D
Got my T67 today and have a few questions.
It came with a 4" Anti surge compressor housing which i did not want i wanted a standard 4" Compressor housing. Will this matter that much?
What is the best way to block the water lines? The shorter of the 2 (Water return??) I was simply going to find a bolt wth the same pattern but shorter and bolt it in nice and tight with a coper washer.
Not sure what to do with the one that goes around the back of the block should i just cut it off shorter and fix a blocked off bit of hose on the other side? Or blank it off at the source, which im guessing is under the plenum?
Any help is appriciated keen to get her back together, tonight i have connected oil feed(One supplied with the turbo is a bit long) and return. Finished replacing exhaust manifold studds.
Also I have one of those NZ manifolds and i am not happy with the way the wastegate pipe comes out it is really really close to the body and air con lines.
Should i modify this pipe or just blank it off and run the gate off the turbin housing?
is this one of the mild steel ones from ebay? i was pretty keen to get one of these for my rb20 anymore negatives?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
