Just bought a td06 20g 10cm ext. gate for my RB , what are peoples experience with using this on the standard manifold?
Is it just a matter of putting in a 12 mm flanger spacer?
Yes and you will need extended exhaust manifold > turbo studs as well.
ran this on my old 34 made 281rwkw @ 18psi.
dyno sheet is some pages back.
if i was to do it again, i'd go high mount with t67-25g
Don't get confused with ppl on NS. The T25 flange housings work mint, no issues. It's those ones that People had trouble with the actuators and nothing else.
the T3 housings with the 3 bolt dump pattern (internal gate off a truck) has proven to suck. Both BSA and another member tried and failed. One was an RB20 one a 25.
I know this thread is 11ty pages long but you actually need to read the thing if you hope to have an idea about the product.
Hi all,
Sorry if this has been covered but after 120 pages (starting at page 1) I couldn't find what I was after and have given up on searching -_-'
Quick overview - R33 RB25det S2 Stock turbo has blown, now buying everything required to get her up and running at 300rwkw+ on 98oct BP ultimate. All the other mods I am ok with (6boost manifold, 850cc injections, greddy style intake etc...) except for two things - Wastegate and Turbo Choice.
Simons write up and numerous results have made the T67 very appealing and I see it's only being released in anti-surge now; that's not the issue though haha!
I just wanted to ask anyone with a T-67, what did you do to have the turbo only running on oil feed? Did you have to weld/close up the water supply lines from the stock turbo? Isn't it better to have a water cooled turbo to keep the oil from 'coking'?
As it is, I'm torn between these two turbos:
T-67
Or
TD06
I'm finding the TD06 more appealing as it is water cooled as well as oil fed. It also seems to have close specs to the T-67 but I couldn't seem to find any recent dyno sheets of performance results. Is it closer to or further from the performance of the T-67? Is full boost still to be expected around 4000rpm from either turbo?
As for wastegates, I have a selection that are available to me and I'm wondering what's best?
(keeping in mind this will be used in conjuction with a 6boost manifold and the target goal of 300rwkw+)
GFB EX 50mm
Or
TiAL MV-R
Or
Turbosmart Hypergate 45mm 2011+ model
Many thanks in Advanced!
Thanks for the replies guys. I decided I'll probably go with a watercooled turbo which, while searching, I found this:
TD06H w/ Garrett T04R
How would this compare to the TD06SL2?
The only difference I can really find is the size of the compressor wheel and the turbine wheel. The T04R has a larger compressor wheel by 6mm and a larger turbine wheel by 6.2mm.
Would I be correct in thinking the smaller wheels on the TD06SL2 would allow the turbo to spool up slightly quicker?
Both are '400-650hp' rated so if the TD06SL2 spools quicker I'd be mad not to go for it as this will be a street build rather than track... thoughts?
Go the oil cooled only T67-25g 10cm without a surge ported front cover.... Loop or block the oil lines!
Plain bearing turbo's don't need water cooling as they hold a lot more oil which is used for cooling.
Waterlines perhaps lol? Yeah I was more inclined to get the T67 but I thought retaining water cooling would be for keeping it nice and cool. I can't seem to find any that are non anti-surge that he has for sale...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
