hypergear highflow or ss1pu .64 for 230ish kw, complete bolt on no hassles.
TD06SL2 20G 8cm for 260kw if you want full external gate no expense on supporting mods spared.
personally I'd put a ss1pu in stock housings on an RB20. Wouldn't even need to think about it.
My predicament is that whilst building a 25/30 id like to have all the neccesary bolt ons ready to go. I dont want something that is too small for the 30 or something to big for the 20. Dont know if that is practacle though. Could a 10cm housing be the way to go when the 30 is fitted. Not after a big power figure just nice reliable engine.
what your wanting is pretty far fetched. its two different ball games unfortunately, and what will be laggy on an RB20 would still be too small for an RB30. thats how different that are.
its really wasted money getting a tune and all that then putting in a bigger motor and needing to do it all again. a turbo that will work on the 30 will just make you cry on the 20.
a nice reliable setup for your 30 though, you can get a hypergear G3 turbo which is more or less a bolt on with the stock manifold and dump pattern. there are videos of a RB30DET R33 with a basic G3 bolt on smashing a 600cc bike on here somewhere. Epic fast it seems, go check it out.
yet if you got that turbo on the RB20 you would need a tiny housing which would still be laggy.... and using the correct housing would be horrible on the 20, and a waste of money to do both as stated prior.
i say wait till the 30 is built.
My TD06-20G is off a twin GTR setup that upgraded to T67s. With a couple of Greddy manifolds one of the TD06-20Gs ended up on my car and the other Fatz's RB30. At the time we were both running 10cm housings and on the 2L RB20 it was too doughy. Changed to an 8cm housing and everything improved. Meanwhile Fatz made something like 245rwkws on 13psi on 98 on his RB30. So would be an animal street car if you ran it to 18psi easily maxing out the 20G compressor without the need to rev the ring out of the engine....
...so I tend to disagree that the same turbo cant serve two different engine provided you are willing to swap A/R of the rear housing
its certainly not that it CANT do it, but rather than you wont want to.
sure enough it will work, but for the effort of a full external gate setup on a heavy breathing RB30 I cant honestly see that it would be justified to make 240kw..
plus, the easiest way to do this setup is hanging a gate off the ex housing and using the stock manifold. if he hangs a gate off an 8cm for the RB20 and then buys a 10cm for the 30 he then needs to get the gate moved over.
just flat out sounds like money is leaking away and overall performance is not on par.
Just saw Fatz made 240rwkws at 10psi :) easky_mad said he is " Not after a big power figure just nice reliable engine" A 20G on whatever boost maxes out the compressor would be a very grunty street car and probably one have to run a very durable 13-16psi. He said he also says he has all the bolts ons ready to go so I dont think it would be a bad option for the situation as he explained it.
A T67 would tilt the balance towards the RB30 with it being a little less suitable for the RB20 but he said he isnt after big power so I take that for a range around what a 20G can do
let me guess you dont like the kink on the straight?
I was never game enough to take it full throttle hey lol...
Full throttle 5th gear right until the kink :) td06 loved it 1.09 in my gtst. Heaps more in it too. No traction tho. Needs a better setup rear end
1.09 pretty good jez..you running stock brakes and all.. Its not the kink i had an issue with, iys pulling the car up after it..lol..I did it flat out to kink the first time, then lift turn brake and nailed it, got 1.17 still..then came off hard on the second and think I kinda lost my nerve after that and resorted to a quil brake dab before the kink, I did have to drive back to Melbourne that night after all...made up heaps of time on the rest of the track and pulled 1.16s all day pretty much..
how were the intima pads jez? I want a set of those also. fark 1:09 is fast.
best I ran was 1:18s, if any of you are on my FB watch the video. I have intentionally edited out the bits that show my car being out horse powered by fairly stock honda civics lol.
the worst part for me was having no real power until 6krpm and the stock 3.7ish diff in the S14. for the most part of the track I was bumbling around in 3rd with no real power.
Ill try post a video tonight if I can.
I wish I had that sort of problem with traction
Makes it exciting. I loved the rush and excitement of RWD on the circuit and not caring if it got smashed up :)
VCT is now working on my gtst, i installed an adaptronic and its working brilliantly. Very inpressed with the Adaptronic ecu's.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
