The T67 should do 400 easy. I sure am getting sick of the anti surge whistle on mine. I now answer the question about the whistle b4 my friends ask what the noise is lol
Mines not a daily so hopefully takes me a little longer to get sick of it.
Hey guys can someone clear something up for me.
I have a TD06H-20G serial on compressor (8371200035). Mine was internally gated but is set-up using a Progate 40 on stock manifold.
I was under the impression i had the larger of the rear exhaust housings because it reaches full boost ~5000rpm (unopened/non-cammed motor)
Before I have a good look at any numbers on the exhaust housing, how can I work out which housing it is?
Obviously I'm wishing to reduce lag with a smaller rear, but just need to sort out how to determine which one I have already. Or is mine one people were having issues with? I dont mind going to a external waste gate rear housing altogether
Cheers.
Edited by Kane_R32
Did you buy it from blake? Aka bsa?
if yours is t3 internal gate then its definitely an 8cm, its the only size they come.
to save money and get the better results, buy a td06sl2 20g core and a 8cm v band rear housing, then reuse your existing comp cover. You will make the same power if not more and spool will increase dramatically. You will need to fab a new dump, and buying the core and housing will be about 500.
Forget the 20G wheel on the TD05 turbine . Just run the 18G compressor (IMO ) Basically the same compressor sheer just a smaller trim. I have one on the bench that i wanted to back to back with my TDO6-20G but its never going to happen so Will be for sale sooner or later with a Trust 8cm rear housing. Would be a good think to throw a 68mm billet compressor at
TD06SL-20G 8cm or TD05-18G 10cm?
Using stock manifold with Progate 40mm controlling boost. Hoping to push 20-22psi
I'm tossing up between these two. Response/Less Lag are more priority over outright power.
Wanting 220+ rwkw with cam gears (obviously exhaust/555cc/pump/cooler/z32 are done).
TD05H 18G should not run 10cm on an RB20, it will be laggier than necessary and wont make any extra power.
The TD05H 18G 8cm will get you the most responsive 220kw out of the Kando range
TD06SL2 20G 8cm will probably get you 240+ kw for your setup, will probably be the same amount of lag as a TD05H 10cm
Hypergear SS1PU will be more responsive than a TD05H 18G and will probably make similar power to what a TD06SL2 20g 8cm will.
FYI I ordered and paid for my SS1PU on Monday, I have a tracking number for it already - its in the mail!
Really depends on my injectors man. At the moment I've got 555s, if I stick with those ill dial my cams for max response and get 230. If my budget allows for a change ill grab 1000s and aim for 260.
I dont recall reading what changes he was going to do.
I'd been talking to him a lot about the specs of those turbos a lot recently (which lead to me buying one).
Im not sure if he will have changed much TBH.
Two of my mates are running these turbos and I'm thinking i might get one for my 25. Wanting to keep it internal gate so it doesn't spoil the sound of my gtsr manifold.
What options do I have for good midrange to make awesome response?
I have the basic stuff. 3 inch turbo back.
Fmic
Surge tank setup with upgraded pumps
Pfc
550cc injectors
Clutch
Diff etc etc
Not chasing large numbers but 250 plus or around about would be good on a safe tune.
Any help would be awesome. I have read through parts of this thread so I understand most of it just looking for peoples opinions.
Adam
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
