Kando Dynamics Turbo
SimonR32
I love how these thing feel like your entering warp speed over 6000rpm lol, wants to keep rising even at redline.
Dont know this feeling :/....
I still have more torque than you :P
when we going for a drive...
Ordered Kando oil feed line kit on Fri, ebay still doesnt show as 'shipped' with a tracking no. etc, even though Mr Kando promised to ship it that afternoon, emailed him this morning, see if he replies by tomorrow haha...
Edited by rondofj
2weeks I think...they cancelled on Saturday due to "lack of interest" was their excuse...there was a few unhappy chaps...they changed the registration process so you can only do it online now..they did this less than a week before the meet and nobody knew, they just thought they could rock up on the day as per usual..
Calm down Ron lol you can't expect to pay 40 for a braided line and all the fittings in that quality and have it teleport to you lol.
its beam me up Scotty, not beam me an oil line Eiji.
20th sounds good. I will have bald semis and as much boost as it will take to fix my engine
your 20 finally on its way? I don't believe lol
sounds like I need to move to Vic.. i can't find anyone just flat out keen for a track day here. It's shit as.
Don't let the boys in wasteland hear you say that...lol
Surprised I don't see you there most of them are blue boys too, drop past whoretown sometime few of them getting keen on track but need a kick in the butt..
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
