My car blows fireballs the size of a car so i dont think its running lean, :yes:
I backed the boost off to around 16psi from 22 to control the heat, it was stupid hot at winton this weekend. It did make a difference, as it should.
Very low timing will result in excessive exhaust heat. It will cause the thing to run really hot, ping earlier than it should when trying to run more boost (capping power) and will also make it get on boost quicker.
I have had a setup tuned like this and am speaking from experience. The car got on boost fine and when/where expected (if not earlier) but the power delivery wasnt right.
No cat, does have a straight through muffler and a res though,
The AFR's were a little rich on the dyno, not heaps just a little to be safe, from memory they were around low 12's high 11's i think. I'm pretty tired from the weekend, i could be wrong i will check later today gonna go see my tuner.
Then yeah could also be timing as above
When you say low timing to you mean advanced or retarded?
The car had around 40-50 on the knock. Nothing drastic.
My car had numbers lower than 10. The tuner couldnt dial in more because the boost was too high straight off the actuator. If we had a lower pressure actuator it would have been a different story.
Is this hitting any points with your setup? whats the lowest boost you can run and did your tuner go all out on the tune with low boost first?
My understanding is the best way to tune works like this: Start with the lowest boost possible and most aggressive tune, slowly wind the boost in and soften the tune as you go.
Rather than get fueling right then add boost and slowly add timing - doesnt work.
I don't think my timing was any lower than 10. Pretty certain it was all higher than 10
We didn't completely reset the boost. Lowered it too around 14psi and went from there. I blew the gearbox on the weekend so once I get it back together, next year, we'll put it back on the dyno to check it again before I buy another 3540 and sell the Kando.
Not giving up yet, i wanna get back on the dyno and have a little more of a play, but i dont think that will change when the turbo spools up and starts running out of legs.
out of curiousity what turbo are you running? what size rear? how much power are you making?
Mook what state are you in? Maybe send your rear housing to Stao (Hypergear) and see if says theres a problem with it.
He stocks these turbos too at the moment. He will be able to directly compare yours to one of his 10cm's and also be able to check for defects. If its not right he can supply you the new housing.
I'm in Victoria, Hypergear is in too melb isnt he?
I'll be able to go see him first, that way i might use a little less time playing on the dyno.
FROSTY, I was a bit disappointed when we tuned it, though its not so much about how much power it made as when and how its making it, very early and seems to run out of legs at high revs, let alone the heat issue.
see to me doesnt seem right! are you sure you got delivered the right turbo??!
do you have a dyno sheet i can look at?
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
