Won't fit on his manifold though.
I'd go the TD06 and enjoy the response if it's a street car. I love the way my T67 brutally ramps onto boost, but if I was using it daily the lag would horn me.
Noob alert!
My 10cm rear might just rock up on Monday, and I'm tempted to fit it up over xmas. Am I right to think it's held on by a clamp? I've never pulled a turbo apart before. If it's fairly easy to do I'll definately give it a crack.
Cheers guys!
edit: Just realised I can look at my other Kando to see how it comes apart *facepalm*
Edited by Run-It-Hard
is it?
boost doesnt kill engines...
mercury motorsports run 40psi thro their stock rb26 lol
Heat(through high boost) kills engines by detonation right? I am sadly only running 18psi on my R34 RB25det due to intake temps approaching 50deg C, was hoping for 22psi :(. Precision 5558 0.63 making 286rwkw
WMI :)
the t67 made 294rwkw on 18psi
Which means the 5558 is not doing so bad 286rwkw @18psi compared to the T67 [email protected] as the T67 is bigger; m thinking of changing my cooler piping AWAY from fan and radiator to make a sort of a rounded 'V' piping instead of the typical rectangular 'C' across the engine to keep temps cooler and allow me to run at least 20psi, heck even 20psi is too low for me.. Do you guys reckon the V piping will improve things (cooling) a bit??
And sorry for spamming the Kando thread aargghh
Edited by rondofj
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
