  On 25/02/2013 at 3:16 PM, Jeremy93 said:
I know its been covered before but i cant search on my phone :(
Will a t67 fit low mounted or is td06 the largest?
t67 will fit if creative.
  On 20/02/2013 at 1:51 AM, Run-It-Hard said:
This is the kinda core I'm using lads. I get where your coming from Scott. I guess I need to decide whether I want the car to look stock and have average power, or put in a conventional cooler kit and gain the missing power I should have, if thats the problem.
Hey i just tested one of these and it had a 6psi drop across it (20-30kw loss), have you tested boost before and after the cooler. Who is it from? the supplier was great and swapped it for another style.
thats why i keep saying spin it around backwards so compressor faces down not up..not sure how much room this will get you though it sure to be a good 10mm or so.. who wants a t67 on a stock manifold anyway thoug you might as well just get a td06...the extra power a t67 has to offer is only being wasted on the stock manifold..
there is always low mount options from 6-boost and such but whats the point in them, it just makes your turbo hard to work on...unless you can get a hks cast manifold that might work ok..
EXACTLY TIMES TEN.
They did some testing before on my first kando and it had a 2psi drop on low boost (I think under 10psi?) so I'd take it as the boost increases the drop will become worse.
I got it off CJauto I think off ebay, can't remember. I found myself a HKS return flow setup to replace it so hopefully I get that extra 20-30kw ... the Stagea needs it lol.
well i ran the 3582r low mounted with 10mm spacer, had heaps of room, now have t67 high mounted and i couldnt tell the difference in comp cover sizes both .70... either way run 15mm or bigger spacer. u still have a shit load of room 4 clearance underneth, u have 2 grind of a few heat shield lugs thats about it..
  On 27/02/2013 at 9:39 PM, Kane_R32 said:
With my TD05-18G, had to use a 10mm spacer vs my old TD06-20G (no spacer), but thats because a TD05 exhaust housing is smaller so it brings the compressor housing closer to the exhaust manifold.
really...my td06 theres no way it would go on without a 10mm spacer...rb25 manifolds different maybe
interesting my td05-18g bolted straight on.
Mind you, my TD06 was the old (shitty) internal gate version. TD05 (external set up) was fouling the compressor housing on the exhaust manifold but about 2-3mm.
Status, what sort of clearance did you have with the TD05 bolted on interms of compressor to manifold?
Yeah his old TD06 was the 3 bolt internal gate type, the shoddy one we all steer clear of.
So now hes on par with everyone else, using a normal T3 Vband housing and the 3" comp cover. Thus using a 10mm spacer like the rest.
Kane how does the TD05H go compared to the old TD06H? Happy with the change?
Correct Scott.
Umm I seem to acheive full boost around 4200-4400 RPM, full boost being 22psi. So definately not as laggy as the old turbo. Very happy thus far. Will post dyno results once a Z32 has been added as the standard AFM is maxing out around 16-17psi..
Awesome dude, sounding really promising.
Maybe grab some cam gears while your on the job? Bring full song closer to the 4k mark, which for an RB20 making reasonable power is a good result :)
I'm sure it also feels a hell of a lot punchier once your moving too, and squirting it in and out of corners. Am anticipating 240kw, let us know how you fare!
haha you just reminded me of whats in my "draw of goodies"... JJR Cam Gears. Will get them and the Z32 in and tuned.
I would be happy with anything over 240 @ 22psi..
Definitely is more punchy, but haven't been able to give it abit of a squirt due to laziness lol
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
