The guy who posted just before your post has put a TD05H 18G 8cm on his RB20 and is soon to get it tuned.
He had a TD06H 20G before and he said its 'definitely more punchy'. you can see that right above your post, if you would so graciously read the thread lol.
as for a TD05H 20G thats not a known good combo. It will have the lag of a bigger turbo without the power. If you want more power than what the 18G can offer (say 240) then get yourself a TD06SL2 20G.
has anyone put either of the td05 18g or the td05 20g on there rb20s yet?
i have read that theve been put on the rb25s and have good response but what are they looking like on the rb20 with response and drift??
Will let you know on here later in the week, I have just installed a TD05H-18G extenal gate 3" antisurge on my rb20. Went External gate as we have had 3 kandos seize the internal wastegates shut and overboost. So Id stay away from them for sure.
went the 18g as all i read on the 18 and 20 was that the 20 made couple of extra kw in the top but lost a lot more low/mid. And compared wheel sizes to that of garrets and the 18g is only slighty by a bees dick larger than a 2871 which would be a perfect turbo for a rb20. and from memory the 20 was close to a 2876 which is a fair old mismatch of wheel sizes and have seen these to be very laggy.
I plumed the a turbosmart 45mm gate into the exh housing of the turbo, and ran a long gate pipe thate curls under the dump pipe so it all fits under a factory 25 heatshiled and cut the 3 bolt flange off a 25 comp cover and welded it to the comp out let to run the factory elbow. ( Road registerd drift car dont want to hae to pay to put it turough emmisions testing)
If you want to run this turbo on the stock manafold in the factroy compressor discharge angle you will need to run a spacer plate between the manafold and turbo, im running 12mm one and the comp housing is touching the maafold heatsheild, but my old vg30 one did the same.
Thanks for all that info.
I have a top mount t04e lag monster at the moment so i would like to change. I have been looking to this style of setup for a while but i think ill stay top mount and try get good results. Ill prob loose spool time by 300rpm because of top mount but ay i dont mind.
Murph - keen to hear what numbers you get. What supporting mods?
TD05-18G is good if you not wanting massive numbers 250-260+ and not wanting to loose too much lag.
Can anyone suggest a good plug gap for 22psi? Or just gap a little, then test drive unitil no more miss up high at WOT?
Hypergear's looking for a tester for their billet TD05H for a dirt cheap deal. be interested to see their version of TD05 compare to a standard version. seeing their result of billet TD06SL2 and T67 it should be following the same tread.
yeah Im not aiming for high figures, I just wanted a relyable turbo which isnt much laggier than the old VG30 i had on previously.
response is more important for me as the car is a drift car. Last G1 comp I managed 2nd in div 2 with 150 rwkw on a stock 20 turbo. Conceded the final as I lost the exh wheel in the 2nd lap of top 4.
Yeah basically I was after a new turbo not a unknown 2nd junk, as my car has to be relyable. If I get 220 ish Ill be happy, Ill see how much injector duty i get up to if im not too high, Im planning on runnig 10% methanol to see if it can take some more mid range timing to get it on as early as possible.
mods are
metal head gasket arp studs, recoed head, tomei oil restricors, drilled out oil drains in head to 9.5 mm celaned up oil drains in rear of head, 6 chamber oil air separator tank draing to sump, extenal sump to rcr cover drain/vent. gtr injectors, split fires, nistune, 600x300x100 twin pass intercooler. 3" exh. Kelford 258 deg cams 8.7 lift ( from memory) cam gears, oil cooler, direct drive billet hub fan with gk teck fan (not runnign a viscos couple)
Os twinplate 25box
prob more shit i cant remember but for a 20 its got a fair bit of fruit
Also it gets tuned on a Mainline dyno, so figures are genrally lower than some other dynos.
Will be gettign it tuned either tomoro or thurs so ill keep posted
What boost you planning to run? I made 213rwkw @ 14psi, unopened, td06 (shitty i/gate) walbro, 550's, cooler, exhaust + nistune. Expecting 240ish with 20-22psi with the td05-18g 3" anti.
Scott - Have 0.8 gap already. Have swapped OEM coils for Supersparks (shhh were cheap), so could it be ignitor related as it was doing the same with the OEM coils..
Try change the coil harness mate, they can cause all sorts of havoc.
Make sure you have adequate earthing at the igniter and to the head. There is a strap from the stock coil harness to the firewall also IIRC and that needs to be sufficiently earthed too.
Ahhh yes. I replaced the harness as my connectors where starting to break. Funny you say firewall, my ignitor is earthed to one of the valley cover bolts?? And the harness is earthed to the last coil pack "frame" mounting bolt??
Do they seem like OEM positions? I have no issues making addition earthing connections myself if you think it will help.
They are definitely not the OEM position...
And they are relying on the motors ability to earth which it would probably have one single strap bolted onto the thermostat housing or similar. Which then goes through alloy to cast iron and back to alloy through layers of gasket goop and mainly relies on the bolts holding it together to earth.
100% you should do up an earth kit and have good earthing to the body AND multiple points on the motor. Make sure your earths are NOT secured to painted surfaces or there will be limited conductivity.
Well ran mine up last wed, and ended up spending the night chasing a missfire issue. Havent sorted it out yet
didnt get a constitant run out of it but had 12 lb boost in it by 3400 rpm and over all response very similar to the vg30 seen did make 226kw probably more in it, but yeah still trying to sort the miss fire issue before can tune properly.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
