Kando Dynamics Turbo
SimonR32
. Running so little boost, running so few revs and being so damn punchy with the 8cm housing would give you a good reliable street setup on an RB25.
what are you babbling about :unsure:
Do you think the result would come better with adjustable cam gears and std cam shafts with that set up? I have them but i cant justify the price of a new timing belt whwn ive already replaced mine 10k ago.
the gears can always let you unlock the best of what you have got, shifting the powerband just enough to make it what you were after.
you wont need to change the belt when you change the gears though. Just put the motor to TDC on 1 and draw a mark on the belt where the mating marks sit on the gears. the new gears will have the mating mark in the same spot.
I think just line everything up at TDC and reference the std markings in the block and timing backing plate etc. Belts can skip a tooth and flop around the crank pulley and when you tensio it back up be a way off where the old markings were. Best go on the block markings and not care about the belt
that's the right way to do it, yet I detected OP did not want to pull lower timing case off as its the majority of the task in changing the belt (done 10ks ago).
in which case you can be dodgey and do it the other way.
myself id do it properly. just sayin'
Ok, So have wasted time and money thinking about the RB25 and 20G setup and leaning on it for all its worth. I want to be sure that walking away from what has been a champion turbo is the right thing to do. Also will give a good baseline for other setups being trialled
So by the end of the day will be interesting to compare:
RB20 RB25
TD06-20G. 8cm 12cm
Cams Std 256/8.5 Tomei
Fuel E85 E85
Both engines run the same inlet and exhaust manifolds. As it is an R32 RB25 it does not have NVCS will be interesting if the better breathing hot side, bigger cams and bigger engine will result in more power then I was making on the RB20
Figured I'd do an update on my setup.
I made 235kw on 18psi, RB25 TD06 20G 10cm.
All you cool cats worked out my intercooler was shit house, you were all right!
I've stuck to return flow as I want it the engine bay as factory looking as possible, but a much better setup.
Ended up taking it for a drive on Monday, left the boost controller on low just to be safe. Low boost was set at 14psi previously, and with the new intercooler it's pumping out 20psi! Crazy how much restriction the old cooler setup made. Pulls like a freight train now too which is great. Also feels less laggy too, win win win!
So thank you for all your input lads :D
Edited by Run-It-Hard
I will need to get it on a dyno soon, needs rego first though (ran out lol).
I ended up finding a HKS type S intercooler kit in Japan and got it sent over. Neat bit of kit, managed to get the return up nice and high too with a bit of moding so I'm all smiles :D
RB20 RB25
TD06-20G. 8cm 12cm
Fuel E85 E85
I'll take a punt and say that the 25 won't wake up down low with the bigger housing, but should shade the 20 between 4-7000. Will be an interesting comparison.
8cm and you reckon it was lazy down low?!
Do you think that's because the turbine was choking at the lower shaft speeds (in that tiny housing) or a different reason?
A 20G shouldnt be lazy down low, especially with an 8cm hey..
I had a 12cm on mine for a month, was so bad lol.
Although it could have had better response with my new cooler setup. Cams might help it out too, dunno. Trent's set it plenty of times that he loved his, he had cams too.
▲ id have to agree! mine had an 8cm rear on rb25 and was way lazy down low..12cm i think will make it more doughy and i dont think up top with that much of an advantage
LOL...really? Something very different between our setups then. I was hitting 18psi at 3,200rpm or something stupid and show was over with the thing losing its pull over 6,500rpm. It was mega grunty with the 8cm housing. And that was with cams at 0 and only a 2/3 tune.
I like the way the 12cm drives but on a very rough tune with no ignition the 12cm housing has generally added 800-1,000rpm to response. Would be far easier and nicer to drive with the way it delivers its power.
Will see if we get any of theloss in response back with the changes we made today....the car got pulled off the dyno due to another car needing some urgent work.
Will keep looking for a 10cm housing but think the T67 will go on before a find the right sized housing for the 20G. That will be the real test as I am pretty sure we have maxed out the compressor on the 20G so the question is will the billet wheel flow more with the TD06-12cm vs the T67-25G 10cm . That will be the real interesting test. Smaller, lower flowing turbine with a 78mm cast compressor wheel VS a larger higher flowing turbine with a lighter, smaller billet 73mm compressor with the larger 12cm housing.
I would go straight for the proven 10cm if I had one so ...no other choice then to waste tuners dyno time with my games :)
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
