Kando Dynamics Turbo
SimonR32
so the official response from Kando is this
td06 - 9 blade: 179g
td06 - 11blade: 220g
overall difference in spool is negligent for $350. No difference in flow wise the advise
Its still a 41g weight saving and you will be 350$ lighter....should have yourself a 10second car now
Has anybody used one of these on an rb20 before? I'm almost keen to give one a shot due to the bolt-on/standard look factor.
http://www.ebay.com.au/itm/Upgrade-Turbocharger-RB20DET-RB25DET-w-Stage-3-Turbine-68mm-Comp-450BHP-/281199995072?pt=AU_Car_Parts_Accessories&hash=item4178d368c0
Would I expect it to behave similarly to a TD06-20g, maybe slightly slower to come on?
I currently have one on my freshly swapped RB20DET S13.
I don't know how a td06-20g spool on a rb20, but this one comes on boost in the low 2000 rpm and hit 0.5b before 3000rpm.
This is with FFP, standard cast exhaust manifold, ceramic coated turbine housing and complete 3" exhaust system, stock ECU, stock tune and stock injectors.
I don't know much more right now.
No dyno yet and no one planned.
I just finished the car, i have a lot of things to do to make the engine bay neater, the PAS pump just died on me and I have to sort the AAC valve getting continuous 12v.
I'll be running the max boost I can with the stock MAF/injectors when I'll get a tune.
Unfortunately it won't happen before several months.
I did some slight pull yesterday, the turbo pulls very well, my cluster isn't working (an other thing to sort), so I can't give you any rpm to boost numbers, the speedo is climbing a little to fast to do the math and know at wich rpm the engine is. :P
I don't know if the turbo is creeping or if kando rate their actuator a little low but I hit 17 psi. :wacko:
The spring is rated 15 psi, and I have the least preload I can have on it.
I'll get a softer spring ASAP and let you know how things goes.
I had an CA18 with a GT2560R and a tune in that car before. The RB is a little less responsive down low, but a lot more anywhere more than say 3500 rpm or so.
i made 235kw with the kando highflow on e85 at 19 psi on a rb20det... tunner says the turbo spikes and if i weld shut the internal gate and add a external wastegate i could see 250+kw...
Hey mate please give us more detail on your car and setup, and provide a dyno sheet if you could!
We can try help you see better results, and the details are always good to share for other members.
RB20DET Internally stock
990 cc injectors
Blitz return flow intercooler
standard exhaust manifold
turbo back 3 inch all the way thru to zorts
split fire coil pack
044 bosh intank fuel pump
Ems ecu
united E85
KINUGAWA rb20/25 highflow with adjustable actuator set at 20psi but spikes down to 18 psi
Greddy EBC (apparently malfunctioning) boost set from actuator...
Nice power curve. :)
The pressure tapering down to 18psi is certainly due to too much exhaust back pressure blowing the flapper open.
Fixing your greddy EBC should place the power right where it should be at high rpm. :)
what it loses in response it makes up in torque....and everybody knows torque wins races
990 cc injectors
Ems ecu
united E85
Thanks for providing that!
What core is in the highflow? TD05/06 16/18/20G?? Regardless of which one the power is low for E85, but telling us which turbo will help me understand how far off target you are.
You should try have your tuner turn the motor a bit longer... RB20s aren't shy at revving to 8k in some cases, and a fiddle with some adjustable cam gears may help you broaden that powerband a fair way.
The only Kando hybrid I know of is a 20G on a T3 turbine wheel in Nissan (based?) housings - bit of a weird combo imho, and 20G probably never going to justify itself in this kind of setup. 16G would have given this power!
They have recently built a skyline specific TD range, but I am not sure if anyone has one yet.
Will wait to see what OP comes back with!
Lithium are you refering at my results? are you saying i should be getting td 20g power level? by the way my tuner was kind of shy trying to push the rb20 he only wanted to go max 18 psi but i kept pushing for 21psi... he was very concerned about reliabilty of the motor...the car was tuned at in car racing in wetherill park the car.
any recomendations to get a bit more power? do you guys think i could crack 260kw if i add external wastegate? adjust the cams? and go to a different tunner? JEM maybe ? i dont think incar racing was up to scratch with the tune.. when i mentioned to play with my adjustable cam gears they said it would make no difference and thats when i knew he was probably not the best tunner to take my car.. only went there because my mate works at the place...
Get a hypergear high flow or a ss1pu, then take it back to your tuner.
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
