So FP are selling their JB HTA for DSMs quite cheap at the moment : http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTDSMFPRED&Category_Code=SP
Haven't quite decided which thread it would suit better, but getting one of these into a Kando housing suitable for a Skyline would be pretty interesting - the FP Red in a TD06H T3 housing could be a crap load of fun, full TD06H 25G power with much better response thanks to the 76HTA compressor.
It's an interesting power than the smallest turbine wheel FP use on their DSM turbos is the TD06, they don't touch the SL2...
I have long wondered about the use of an FP DSM item in a Kando housing.
I contacted FP many times asking for a T3 variant but they refused. Told me to build a custom manifold. I also quizzed them on the origins of their 67mm wheel and if it was a TD06H, they denied using a H wheel and would only tell me that it was a 'wheel of their own'.
Quite a PITA if you ask me but I do not doubt that a Kando housing could be made to suit without much effort. Someone SHOULD try it on some sort of 2.5L....... COUGH ARTZ
Don't hold me to this, but I am pretty sure most of their turbos are just off the shelf turbines and they hide the combos - I believe the 65mm turbines are TD06, and the 67mm ones are the TD06H, and that even means the BB core versions (I had discussed with Rob whether it was possible to make a BB core twin SL2/68HTA type beast for a nut case lowmount RB26 twin setup and he indicated if someone were willing to pay....)
The original famed FP Green was just a TD06 with a Garrett 50-trim T04E compressor, a lot of their combos come down to doing excellent turbine to compressor matches as opposed to reinventing the entire wheel - which is a worthy cause if the result is greater than the sum of the parts.
The FP Green HTA in a Kando TD06 T3 externally gated housing, if I am correct - would be a relatively inexpensive weapon for the performance it could offer, which we know the compressor for is capable of 350-400wkw on E85.
LOL, I have one but with the 73HTA compressor. Is a good thing. Tad more responsive than the 20G depsite being 5mm bigger on the compressor and the turbine is a much later model thing with the same basic dimensions as the TD06 65mm turbine but different qty of blades and rake etc.
The L2 turbine simply doesnt have the torque to turn the higher flowing compressors which is why they typically dont touch them. I dont get the fuss over the L2 turbine. I sold mine as numerous L2 setups tuned by the same tuner on the same dyno as my plain TD06-20G got the same result give or take a few kws...if anything mine always pipped the L2s ?!?!?! Maybe on higher flowing setups rather than ashmatic RB20.
If only I can get 10cm housing for it as the 8cm was alight swtich on full boost at something like 3200rpm but nothing over 6,000rpm...and the 12cm made it way too laggy. 10cm is right in the sweet spot...but hard to come across cheaply
Kando 10cm T3 housing is $200 delivered.
Send it to Stao and $150 later it will suit your 73HTA unit.
Don't hold me to this, but I am pretty sure most of their turbos are just off the shelf turbines and they hide the combos - I believe the 65mm turbines are TD06, and the 67mm ones are the TD06H, and that even means the BB core versions (I had discussed with Rob whether it was possible to make a BB core twin SL2/68HTA type beast for a nut case lowmount RB26 twin setup and he indicated if someone were willing to pay....).
You mean like this
http://m.ebay.com.au/itm/281305058842?nav=SEARCH
  • Like 1
Sortof, yes - except the 68HTAs will outflow and generously out-response the 20Gs, hell even the 73HTAs out response the 20Gs... as Roy mentioned earlier.
On an RB30 a pair of 68HTA-SL2s would be ruthless. Well twin 20Gs would be too, but you are getting into "BIG turbo" territory
  • Like 1
What would be interesting is the TD05-20g with the 9 blade rear wheel and that 68mm billet compressor :)
Edit; found em
http://m.ebay.com.au/itm/271447837223?cmd=VIDESC
You know that wheel is well different to the 68HTA? On that note however, the billet 16G or 18G themselves are pretty potent. Will ponder on how worthwhile a change from a GT-RS they would be, however.
How hard would it be to fit the 68hta wheels to the TD06 if one got the non billet type pair ?
How would the the billet 18g wheel comparing to the 71mm GT wheel of the GT-RS, or even fit the 68hta wheel to the TD05, with the bigger exhaust wheel should let the exhaust side breath out better, even more so for the TD06
What's the difference between 16-18-20g wheels ?
XKALABA just be awares that I have known 2 people so far to have poor results from TD06SL2 T25 IWG housings, and have known none to be successful.
The housings work FINE for TD05H application as proven by a few of us, however I personally ONLY have negative results for the same housing used with a TD06SL2 core.
Food for thought :thumbsup:
    • Wrt the engine, you're very much limited by 'production quality' as to how much extra power you can extract from them (I'm talking i6 red-motor) -- a lot here depends on how 'authentic' or 'period correct' you want the modifications to be... ...I'm too old... <grin>...the first true performance engine Holden made, was in the HD/HR models ~ this was the 'X2' performance pack...it came with twin downdraft strombergs on an otherwise unimproved intake manifold, with a two piece exhaust manifold (reckoned to be as good as extractors)... ....these engines were built upon the '179HP' cylinder block, which included extra webbing in the casting to make it stronger and less susceptible to block distortion... The next performance i6 came out with the HK Monaro (also found it's way into the LJ GTR Torana ... the car I wish I hadn't sold)...it had pretty much the same manifold setup, but was built against the '186S' block...this block retained all the extra webbing of the 179HP block, but added a forged steel crankshaft (instead of the stock cast crankshaft), because it was possible to snap the crank... ...apart from the inherent weaknesses in the stock (cast crank) blocks, the next limiting factor is the cylinder head porting & combustion chamber design, and the actual valve sizes. Back in the day, you could buy a 'yella terra' cylinder head (from stage 1 to stage 5 gradients), and this was the way to get serious power out of them -- with the extra breathing of these heads, you could fit a triple SU or DCOE Weber setup... ...obviously, these mods were a waste of time on a stock cylinder head/camshaft grind. My housemate rebuilt the i6 in his VH dunnydore about 6 months back -- this is a 186S block with the 12port 2850 blue motor head and intake/exhaust manifolds, with a dual throat Weber off an XF Falcon mounted on an adapter plate ; it's not a bad makeup...got more torque & fuel economy just light-footing it about on the first throat, but stand on it and it makes more giddy-up than the standard 2850 blue motor that it replaced. Personal note: I'd just fit an RB30 and be done it it 馃槂
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
