So FP are selling their JB HTA for DSMs quite cheap at the moment : http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTDSMFPRED&Category_Code=SP
Haven't quite decided which thread it would suit better, but getting one of these into a Kando housing suitable for a Skyline would be pretty interesting - the FP Red in a TD06H T3 housing could be a crap load of fun, full TD06H 25G power with much better response thanks to the 76HTA compressor.
It's an interesting power than the smallest turbine wheel FP use on their DSM turbos is the TD06, they don't touch the SL2...
I have long wondered about the use of an FP DSM item in a Kando housing.
I contacted FP many times asking for a T3 variant but they refused. Told me to build a custom manifold. I also quizzed them on the origins of their 67mm wheel and if it was a TD06H, they denied using a H wheel and would only tell me that it was a 'wheel of their own'.
Quite a PITA if you ask me but I do not doubt that a Kando housing could be made to suit without much effort. Someone SHOULD try it on some sort of 2.5L....... COUGH ARTZ
Don't hold me to this, but I am pretty sure most of their turbos are just off the shelf turbines and they hide the combos - I believe the 65mm turbines are TD06, and the 67mm ones are the TD06H, and that even means the BB core versions (I had discussed with Rob whether it was possible to make a BB core twin SL2/68HTA type beast for a nut case lowmount RB26 twin setup and he indicated if someone were willing to pay....)
The original famed FP Green was just a TD06 with a Garrett 50-trim T04E compressor, a lot of their combos come down to doing excellent turbine to compressor matches as opposed to reinventing the entire wheel - which is a worthy cause if the result is greater than the sum of the parts.
The FP Green HTA in a Kando TD06 T3 externally gated housing, if I am correct - would be a relatively inexpensive weapon for the performance it could offer, which we know the compressor for is capable of 350-400wkw on E85.
LOL, I have one but with the 73HTA compressor. Is a good thing. Tad more responsive than the 20G depsite being 5mm bigger on the compressor and the turbine is a much later model thing with the same basic dimensions as the TD06 65mm turbine but different qty of blades and rake etc.
The L2 turbine simply doesnt have the torque to turn the higher flowing compressors which is why they typically dont touch them. I dont get the fuss over the L2 turbine. I sold mine as numerous L2 setups tuned by the same tuner on the same dyno as my plain TD06-20G got the same result give or take a few kws...if anything mine always pipped the L2s ?!?!?! Maybe on higher flowing setups rather than ashmatic RB20.
If only I can get 10cm housing for it as the 8cm was alight swtich on full boost at something like 3200rpm but nothing over 6,000rpm...and the 12cm made it way too laggy. 10cm is right in the sweet spot...but hard to come across cheaply
Kando 10cm T3 housing is $200 delivered.
Send it to Stao and $150 later it will suit your 73HTA unit.
Don't hold me to this, but I am pretty sure most of their turbos are just off the shelf turbines and they hide the combos - I believe the 65mm turbines are TD06, and the 67mm ones are the TD06H, and that even means the BB core versions (I had discussed with Rob whether it was possible to make a BB core twin SL2/68HTA type beast for a nut case lowmount RB26 twin setup and he indicated if someone were willing to pay....).
You mean like this
http://m.ebay.com.au/itm/281305058842?nav=SEARCH
  • Like 1
Sortof, yes - except the 68HTAs will outflow and generously out-response the 20Gs, hell even the 73HTAs out response the 20Gs... as Roy mentioned earlier.
On an RB30 a pair of 68HTA-SL2s would be ruthless. Well twin 20Gs would be too, but you are getting into "BIG turbo" territory
  • Like 1
What would be interesting is the TD05-20g with the 9 blade rear wheel and that 68mm billet compressor :)
Edit; found em
http://m.ebay.com.au/itm/271447837223?cmd=VIDESC
You know that wheel is well different to the 68HTA? On that note however, the billet 16G or 18G themselves are pretty potent. Will ponder on how worthwhile a change from a GT-RS they would be, however.
How hard would it be to fit the 68hta wheels to the TD06 if one got the non billet type pair ?
How would the the billet 18g wheel comparing to the 71mm GT wheel of the GT-RS, or even fit the 68hta wheel to the TD05, with the bigger exhaust wheel should let the exhaust side breath out better, even more so for the TD06
What's the difference between 16-18-20g wheels ?
XKALABA just be awares that I have known 2 people so far to have poor results from TD06SL2 T25 IWG housings, and have known none to be successful.
The housings work FINE for TD05H application as proven by a few of us, however I personally ONLY have negative results for the same housing used with a TD06SL2 core.
Food for thought :thumbsup:
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
