Yeah, I'm not sure which one to go with, the TD06H comes with the T04R compressor aswell.
I'm picking out of these 4:
T67/T04R billet compressor - Anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-T67-w-Garrett-T04R-wheel-T3-10cm-Nissan-RB25DET-/291177385706?pt=AU_Car_Parts_Accessories&hash=item43cb864eea
TD06H/T04R billet compressor - Antisurge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-TD06H-TE06H-w-Garrett-T04R-wheel-T3-V-Band-10cm-/281375447822?pt=AU_Car_Parts_Accessories&hash=item4183489b0e
T67-25G Billet compressor - Anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-Anti-Surge-T67-25G-T3-10-cm-V-Band-Housing-500HP-/281375446227?pt=AU_Car_Parts_Accessories&hash=item41834894d3
T67-25G Billet compressor - Non anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-Non-Anti-Surge-T67-25G-10cm-A-R-73-T3-V-band-/291181230987?pt=AU_Car_Parts_Accessories&hash=item43cbc0fb8b
I'm guessing the 4th option would be the most responsive seeing as it doesn't have the antisurge housing. The TD06H being the laggiest of the 4 having the bigger 58mm turbine, but would flow more top end? Does anyone know how a T04R performs against the 25G compressor? Which would be the better option for a street car.
If you're purely looking at the Kinugawa range then on a RB25 you'd look closely at the T67-25G and E85.
You might also look at the Hypergear derivative, evidently his thrust bearing is a worthwhile upgrade - unless Kinugawa are/have incorporated something into their range.
I would like to leave room for 350rwkw
I think the Kando one maxed out at less than that from his testing, but that was with the cast compressor.
That is GTX3071 territory on e85 with much better response.
well the choice is easy...your only choosing from 2
you can't run a66- 67mm T04rcomp wheel with that turbine, unless you like lots of lag, not much power, peaky all or nothing delivery and get flogged by everything
you need at least a 65mm turbine to drive that comp wheel..
history has proved it over and over again..vl rb30 owners where doing stupid shit like this 15yrs ago..
cheers
darren
Edited by jet_r31
figure looks stupidly high for only 98 and low boost. but my t67 is up around 360kw atm on 22psi e85.on song around 4k on road.
car went in for tune on bigger boost last week, but fuel pressure is dropping off above 6k so chucking in walbro 460lph pump to see if that will help with the problem.
yea just bp 98. really happy with results so keen to drive it. should go 400. pluss on e85 and more boost.
but it will stay how it is plenty enough for drifting
Any more info on setup? Cams etc..
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
