Looks nothing like the external Vband housings I usually modify for external gates off the housing. Why do you have your heart set on a 39mm PT gate? I can get Turbosmart gates pretty cheap atm...
Anyone here used one of these??
http://shopping.kinugawaturbo.com/kinugawaturbochargerbolt-on24inchesnissanskylinerb20detrb25dettd05h-16g8cm10cm-1-2-1.aspx
I was thinking of getting one and the garret billet wheel has caught my attention.
(Going on RB25DET NEO)
Edited by vodkashot
Nothing inherently wrong with the rotating bits. The housings are likely to be physically small and not capable of flowing what the wheels can push. They do build turbos with housings more commonly fitted to those wheels.
If you want "bolt on" Kinugawa then maybe look at the TDO6SL2-20G.
Hey guys, My R32 goes in for a tune on friday. Im hopefully looking to get atleast 300rwhp. What do you's think would be an estimate of what im going to make.
The mods are - Stock Rb20det
Td06-20g 8cm sl2 v band on stock exhaust manifold
38mm Tial External Gate
18 pound boost
550cc injectors
255lph fuel pump
z32 afm
Nisstune.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
