that what eiji class them as a td06h we talking kando's/kinugawa not trust/greddy
More or less.. Kando drops the S from all models except the L2..
Strange that he does that but no big deal. Once you understand the MHI family you read TD06H and TD06SH as the same item, no biggie. You just need to be mindful of the wheel sizes and bladecount on some of the H models as they can vary between 11 and 12 blade.
Will be interesting to measure up my turbine on my TD06-20G. My Trust compressor cover doesnt have any prefixes after the TD06. So I thought this may have meant it was a TD06S in Mitsu speak. I was trying to equate it to a Kando turbo and his plain TD06 is a bigger wheel and would not fit inside the T67 turbine housing like mine does. I believe my wheel shares the same dimensions as the L2, just has 12 blades or different pitch/back cut etc.
roy, does your td06 have a 2" comp housing outlet? the kando turbos come with a 2" and i'd think it's a tad small lol
unless you go a 4 in compressor cover which has a 2.5in outlet as linked below or the t67 turbo has a 2.5in outlet.............. the rest all have 2in outlet
http://www.ebay.com....=item43acaf314a
one other thing what be the a/r of the 3in compressor covers cause i see eiji has the 2.4 cover as a a/r .55 ?
Edited by stocker
Ok, so...now I just need to find a week and about 2k for dyno and spanner time. The quest to find the ideal setup on an RB20. The turbos I have to try with my 6boost manifold and Turbosmart gate are:
TD05-18G 8cm
TD06-20G 10cm
TD06L2-73HTA 8cm
TD06L2-73HTA 10cm
All to be benchlined against my TD06-20G 8cm.
The best setup will also get my baby Tomei Poncams installed and tested and then whichever setup looks the best will get a gut full of E85. It will have to go back to 98 but going to lean on it and see what I can get my track times down to with my next purchase of new tyres. Once they are past their best will throw it back to 98 for convenience. I hope the TD06L2-73HTA 8cm lives up to its promise as I want to see how a std RB20 will handle 15min track sessions with that sort of power.
I know I should not get my hopes up but am hoping I can get about 260rwkws from the TD05H-18G with E85. Would be nice if I can make +310rwkws with the 73HTA. It is meant to flow 54lb/min, which I suspect may be the start of where it may be worthwile having the baby cams with the plazmaman
I have a Trust T67-25G and TD06SH-25G laying around but they are way too much turbo for an RB20 and they are sitting around waiting for my RB24 :)
Its basically a hack job Mistu turbo by Forced Performance. They have a 73mm billet compressor, hence the 73HTA tag. Mine runs an L2 turbine and will throw my 8cm housing on it. Meant to flow 15% more then an 20G wheel for the same response. Will see how close it comes to the claim. Be nice to have T67 power with 20G response :)
am so keen to see your results roy as within the next 12 months ill be upgrading turbo and would be awesome to see what sort of response and power the td05 18g will give....and what will happen with the poncams.....
thats a big ask but it is a nice looking wheel, how bigs the cover, I'd be keen to give it a go on my setup.. :yes:
So i find it on there site, but does it usually comes with an L2 wheel,or is that something u have done??
TD05-18G 8cm
TD06-20G 10cm
TD06L2-73HTA 8cm
TD06L2-73HTA 10cm
Ooooh , interesting , when you do this , can you write out your full modification list sorcerer.gif
Roy how much did that 73HTA set you back? I have been considering getting one :)
The ones you see on the FP site are stock fitment with stock based housings for certain models
Its the same 3" cover as my 20G, just machined for the larger wheel. The compressor is larger in diameter, but it is lighter so will be interesting to see if there is an increase in lag. Along with dynos will do some in gear testing with the AiM and log rpm vs road speed vs boost. Should paint the full picture of what turbo makes for the faster car
Mine is a bit of a custom jobbie getting built up locally with an EVO centre housing so has later model, more durable bearing design and water cooling and the L2 turbine. May be ok, could be a disaster. Then throwing the 73HTA compressor at it. How much? LOL...the real question is why do i have five turbos, valued at ~7k of turbos sitting around doing nothing :(
If it works you will be able to buy one off me on the following proviso..you own an RB20 :)
TD05-18G 8cm
TD06-20G 10cm
TD06L2-73HTA 8cm
TD06L2-73HTA 10cm
Hey Roy, what size housings you got on the TD06SH-25g? if you wanna get rid of it let me know.
It's a 10cm housing. Not sure I want to sell it any more. I cant really sell it as who is going to pay over 2k for it when you can get a Kando for ~$800 :(
Actually looking at these pics now the compressor cover tag says TD06H. I thought it said SH? Anyway, its the same turbo from the earlier page side by side with the L2-20G
wow 2k, I never realized thats what the Trust branded 1's were worth. I was thinking of offering you what a KD was worth lol.
When you look at the turbo on a side profile, I'm amazed that the tiny little turbine housing flows what they do. Since you have played with these turbo's so much whats your opinion for a 3L & TD06H-25G with 3",3" port shrouded & 4" inlets. what housing would you choose? Would there be any advantage that you can think of by using the TD07S housing version's of the same turbo?
cheers for your help.
Yeh, its only done dyno time so like new. But nobody is going to pay $2200 for it when you get get a "Kando the Great" for $800.
If I had an RB30 i dont think i would run any of these turbs. I think you would get a better result out of the GTX3076, more responive and the billet compressors seem to give you a bit more legs at higher pressure ratios. So probably bag you a more responsive 350rwkws.
TD05-18G 8cm
TD06-20G 10cm
TD06L2-73HTA 8cm
TD06L2-73HTA 10cm
Awesome test, looking forward to hearing the results! I'd love to have seen a 68HTA in the 8cm TD06 housing too...
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
