i've noticed how my kando rear housing is bolted to the chra is pretty poor, i've seen some with v-band and some with garrett style fittings but for some reason mine is different.
ARTZ/JEZ, how is your rear housing bolted to the chra?
The T3 housing you have is a Kando specific item, it bolts on like a garrett one does.
The MHI/Trust style housings clamp on... Like the MHI and Trust ones do.
No big deal, its fine.
oh cool, thanks for clearing that up Scott.
some progress - still got plenty of room so i rekon its possible to squeeze in a T67 down there with a large spacer :D
Blake should be coming today or tomorrow to do the intake, cooler piping & screamer, and finish off the dump pipe. then tune in mid-end of Feb.
should get blake to tig the splitter shut, then machine the flange surface flat again.
then use one gate on either side of the splitter...... and bolt a T3 TS GTX3071 to it.
wrong thread.. :domokun: to self.. but had to say it looking at the manifold pron above (not the sexiest thing but theres an element of sex when you know it gets the job done ;)).
You can't get to the bottom of the mani I wanted to do that but not enough room the pipe is welded in the middle of the splitter perfect flow yes they are not very sexy but it works
You can do anything you set your mind to ;)
Especially if you CNC a divided spacer plate to go with it.
If I ever own another skyline we will pioneer this one together :nyaanyaa:
I want someone to take the tweaked log manifold with gate and then go and spend the extra $1000 on 6boost and $300 on pipng changes and report back. :)
Hypergear has some relevant results to that.... Hes shown where the stock manifold caps out and how he went with a stock position log.
I think the stock manifold has capped him to 320 but isnt too bad in terms of spool.
I am pretty sure the RB20 likes a manifold well before then. They really seem sensitive to back pressure and exhaust flow. The other RBs dont seem so sensitive to exhaust flow, but the little exhaust pulses of the RB20 seem to need some manifold help to spin the turbos. The full TD06-20G setups on RB20s always outpeform the bolt on setups. Even those that have had the exhaust housing gate mod or manifold gate mod
My theory is the stock mani can't flow past 320 because it becomes restrictive but when the external gate is added it would allow more flow and give more power I would like to see a t67 strapped to one and see when it stops making power due to the manifold
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
