both style.
But I think Kando can only do 8cm TD06/T67 housings in the Mitsu/Trust 3 bolt housing. They couldnt do me a TD05 housing or TD06H Trust style housing. That was 6 months ago so maybe doing them now?!?!?!?!
30% extra air flow should make quite a big power difference maybe even some more response u going to try one simonR32 ill be keen after seeing some results ??
I have been looking into this a fair but and its so hard to get reliable information. From what I can see there is the usual common sources of suppliers. I understand the FP ones are unique, and the BBK ones are unique. There are several other US places doing billet wheels and talk on US forums is that they dont get the response/improvements that the FP wheels get...and it appears they are a common supply. Ditto the BBK wheels which on US forums seem to have them a little behind the FP wheel.
I think I am going to try the 18G then hi-flow it with a 68HTA wheel and see how it looks. If I can get something that hammers on the RB20 then it will be a good thing on the RB24 :)Anywhere around 270-300rwkws is nice. More then anything I want 250rwkws from 4,750rpm
The talk on the 73HTA vs 20G is a genuine increase of 15% in power for same response...on some setups a tad better transient response. So if simply throwing a billet wheel at my 20G has me going fr0m 270rwkws to 305-310rwkws on 98 then I will be the happiest guy in the country. If that goes to plan I will be in all you T67 guys ear to try the 76HTA
I would love to know for real if there really is any difference between the Blouch, CBRD, Forced performance compressors etc. It seems to me the biggest variable is the turbines. Some run GT30 turbines, others cropped Mitsubishi turbines. There is probably a lot of hit and miss with the wheel cropping versions
30% lighter is great, not sure about the 30% extra airflow. Its got the same trim and diameter as the standard part. Not sure how that could flow 30% extra. If it can be spun faster to produce more flow that's one thing, but, whether or not a gain can be had really depends on the compressor map- which we don't have.
Seems most of the talk is around the shank of the turbo. The billets being thinner so you actually get more surface area of blade . Well at least thats what the CBRD crowd really emphasise
You can see a small difference in the pics for the adverts
http://www.ebay.com.au/itm/Turbo-Billet-Compressor-Wheel-7075-AL-T67-25G-TD07S-25G-Extra-30-airflow-/270897143127?pt=AU_Car_Parts_Accessories&hash=item3f12ba5d57#ht_2045wt_1270
http://www.ebay.com.au/itm/Turbo-Compressor-Wheel-Mistubishi-T67-TD06SH-TD07S-25G-/290657757814?pt=AU_Car_Parts_Accessories&hash=item43ac8d6a76#ht_2173wt_1270
LOL, more then anything all I want is one of those pretty billet nuts that go on the comrpessor :)
Yes well im purchasing the t67 this week just wondering weather its worth going the billet or just staying how it is. Really interested to see back to back dyno results, I just dont want to be the one to do it as i dont have the cash
I dont think it will be any worse, potentially better but your talking about a lot of supporting mod.......................
Im sure for them to say 30% more flow that is what it did per RPM on a test bench. Real world application is what could differ. Stao has already done this, while the compressor could flow more I dont think he could easily access it without other revisions... 200 page read to find out too lol
Scott it's hard to keep up, but your post earlier today suggested that the flow increase was related to the round inlet/ 3 bolt style turbine inlet. And that was the direction/purpose of my enquiry.
Then things moved along seamlessly with comments about extra flow capacity related to bigger/different billet compressors.
So what gives? Consensus or hard information about whether Mitsu-style 3 bolt inlet is a good thing?
Who knows? Tial seem to think that if they are going to go to the trouble of making housings for Garrets that they do v-band round rather then square. But then EFR range which are meant to be all things in turbo design are square...but then the TR30R is round....so who knows. Doubt it makes a poofteenths difference in the real world when running on a car. I suppose in theory you can have the same A/R and flow with less friction losses against internal wall of housings.
Yes I did think it should offer a theoretical advantage, hence the question.
The Tial V band inlet/outlet fastening method is very attractive to me from an ease of servicing/installation viewpoint.
A mate who runs an Evo gravel rally car (with anti-lag) has experienced a lot of trouble with the 3-bolt flange nuts coming loose in just one stage (so as little as 20km of competitive driving). Extreme heat cycling partly to blame, but it was fixed by sourcing flash Ralliart spec nuts and conical spring (belleville) washers. Cost to regular plebs like us would be 4.50 per washer (need 2 per stud), and 21.50 per nut... Madness but that's what it takes to keep the bastards tight.
Slight deviation, but makes me wonder if the 3 bolt spec is more prone to having the flange nuts loosening themselves?
LOL Sorry mate, was distracted by the tennis..
Two different topics. One guy posted he heard the 3 bolt housings work better, to which I agree that I have read 30% better. Then Simon showed a billet 25G wheel which also states 30% more flow..... Which my hypergear related comment was aimed at.
Sorry to have been confusing and probably posting too often, let me know if that clears it up.
I was running Grade 8 bolts and they were typically shagged after a track day. Next week of driving would have small exhaust leaks which I could nip up but were a pain in the ass. The original Trust studs were tops...but when my car went to a workshop for some work all the studs were repalced with bolts and hence the problems started.
Majority of turbo suppliers do them. I got mine from a place in Melb but pretty sure GCG and others all do them. You can easily get them on line from US and if you are like me and never have any time to go buy stuff from actual places so want to buy online
30% lighter is great... As others have said the extra flow comes from the shank being smaller and not the actual blade diameters.
BUT if there is 30% extra airflow that is going to cause less boost response and more lag for sure. What people forget to think about when looking at flow sizes is no matter how heavy the compressor wheel is, that weight is going to be nothing compared with the force required to push the extra volume of air.
I want to give the billet wheel a go, but I will need some convincing that the redesigned compressor wheel is going to be better :)
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
