Now lets see them do a billet 16g and whack it on a TD05H rear end.
I find it strange now that we had always discussed the TD05H and 20g being a mismatch, but FP are using TD05H rears with their HTA compressors which are meant to outflow the 20g - thoughts?
I am considering buying an FP Green with the 44mm WG outlet on the evo 3 style exhaust housing. Then order an SR-MHI 6boob and go spastic
heres some piccys for you to have a gawk at... :woot:
how she sits..
I gave the intake pipe a scrub, then painted it black.. :ninja:
And the dumps, dumps into a twin HKS pipe, Scotty doesnt like my design, he wanted to build me a whole pipe but i reckon it will work alright,
if it doesnt I guess he will get his way .. :dry:
some things I have wondered should I have done differently...maybe 3.5 inch dump..and tempted to just stick a 4 inch intake pipe with pod as well...not sure if there is much to be gained though
Mines all ready to go..all I need is a silicon joiner for the turbo outlet (which is on its way) and a bung for an unwanted hole in my fuel rail...then put it all together properly..everything has been test fitted..
Scotty likes to lobster, I like to let him.....Screamer is close to the dump, maybe I should poke it through the bonnet :P
I need to plug my adaptronic in and attempt to rough tune it..but this can be done on my laptop..then hopefully I can fire it up this weekend :thumbsup:
3" is plenty with a venting gate, mine is only 3" and handles a lot of power. 4" intake isn't really needed, just make sure you have a good K&N 3" filter :thumbsup:
screamer looks pretty close to the dump, might just be the angle of the photo tho.
And? Doesn't really matter :)
Finger crossed for good results ARTZ, E85 or BP98? Who is tuning?
Also don't skimp on the graphs, we want boost, torque, afr and power :banana:
Edited by SimonR32
^^^LOL you build it on a poor man with kids budget and get back to me on that....
Yeah i forget the gate venting seperatly..should be fine
E85 or BP98 is the only choice I have to make actually...cant make up my mind on that..both a are plentiful but I do like to go for long drives..
Plus if I tune for 98 I still have something to look forward to later..But yeah, really undecided still..
Trents gunna tune it for me..
Don't u have a data Logit thing? Get Trent to do tunes for both e85 and bp98!!
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
    • House of Fatz dry dock needs a clean sadly one of the long time stables is leaving this weekend   see ya mr purple
    • Hence why I've only modified my car into a pure daily. Everything has to remain reliable & roadworthy, while providing value and grin factor. It also must not be handcrafted to the extent that the car will be immovable if something breaks because you cannot get or make a replacement to at least limp around with.
    • Nah, I definitely do that kind of stuff with my car. I do drive it around as a daily! It's just that mindset about building a car to actually still use/retain it's function as a car is rare. If you modify your car into a weekender, IMO you've ruined 5/7ths of the fun. It should remain fun to do daily errands in.
