I doubt the 25g is out of flow, I did go an extra 30kw more than that. I would be pointing toward the cam timing being a bit shonky like most RB30's... There is no way that should dive like that after 5000rpm and when I have seen them do it in the past it's because the cam timing isn't set correctly
EDIT: I didn't realise it was a shitty R32 RB25 head, so that is probably more the reason :whistling:
Isnt there a difference in the fuels you are both running? Are you really making 30rwkws more then him? I have seen a few well setup R32 RB25 heads make great power. Its not the head as much as I understand it to be what is basically an RB20 inlet plenum. I know even at 270rwkws and RB20 that my thing now holds power far better after 7,000rpm with a new plenum. At 8,000rpm I make something like 30rwkws more. I do lose power through the mid-4,500rpm though
.... why do you persist??
Its in the car, I barely touch it and its reliable. In the 9 years I have been running the TD06 setup, I have tried cams which cost me about $800 all up after I sold them. I tried the plazmaman plenum which is about a 1.5k waste but something that did give me potential for more top end on the RB24. And I swapped the Greddy setup for a 6boost as part of a refresh after 6 years of fun with my setup. So all up have maybe spent ~3k on the RB20 after the TD06 was installed. To me thats not bad value for a setup as old as it is that has been tweaked to see if there is anymore in it.
The Greddy turbo has been healthy for about 70,000kms as well and 9 years. I have been away for about 2 years of it so more like 7 years of use
I have never felt it justified to go and spend a packet in one hit to do anything to another bigger RB. Its not like I have spent a lot of money on this one. It cost me $600...I have seriously spent more on oil changes and tracking it then I have on the motor and any farting assing about. :thumbsup: But I do buy bits when they are cheap for my standby engine in case something should happen to the RB20.
In the meantime its the cheapest way I can get to the track. The main reason I persist is I have had the car in this basic state since 2003. If I go and do major changes then all of a sudden its not as much fun if I go to the track and go quicker. Running the same basic car at the track is loads of fun. Same basic car means you chip away at PBs and when you go quicker you are stoked. You go slower and its frustrating but twice as rewarding when you are out there next and for a variety of reasons you beat your PB with the same basic car. I have improved out of sight as a driver, and truth is still need to improve a hell of a lot to even exploit the pace currently in the car with the RB20.
Once I have done a 12 flat qtr. A 1:19.xx at Sandown. A 1:34.xx at Winton and a 1:47.xx at PI then I will may pull the RB20 out. Until then it stays as long as its healthy
Yeah this is a good point, if its working why change it. If for any reason you do need to pull it out though I wouldn't hesitate to get a cheap 25 det block and put that in.
...If for any reason you do need to pull it out though I wouldn't hesitate to get a cheap 25 det block and put that in.
Except that its my motto that "People who put RB25s into R32s are the sort of people that would sleep with a mate's girlfriend. She may be an OK sort but you go there because she is easy. At least with an RB26 you have the excuse that she is a great sort but often warned off because of the associated price tag" :thumbsup:
"R32 owners still with the RB20 are the loyal guys who adopt other peoples abandoned dogs from the RSPCA and cherish those 10yr old thongs and hat as they think it gives them character" >_<
Have to say but the 20 in my opinion sounds the best
I agree, don't know if its the revs or me having flashbacks of watching the R31's race as a kid, but 9 times out of 10, the 20's are the nicest sounding of the RB's..
cheers
darren
Edited by jet_r31
cheers
darren
Oh SOUNDS the best.
Shit yes, rb20 is hands down the best sounding RB there is imo.
Yes, I think all RB owners wish their cars sounding like this...
Cars are an individual thing. You have to be able to laugh about the folly of modifying any car and best to keep your sense of humour. Build them for yourself and you will never be unhappy and you wont honestly give a f**k what other people thing about it :thumbsup:
I think it starts life out as a TO4E. But the turbo is pretty customised. A friend has a restored R31 Gibson car, complete with spare blocks, heads, gearboxes...tasty stuff. They make about 300rwkws depending on boost. The turbo isnt std GTS-R. Just like the RS500s, they started life as a T04...but then... :whistling:
you will shit in a 12.... a customer just ran 11.1 with slipping clutch and he makes just over 300. Honest 10's in it.
https://www.facebook.com/photo.php?v=10150516676036519
Yeh I ran a 12.9 with only 14psi as any more and my ignition broke down due to the std coil packs I had at the time. That was on RE55s so pretty decent tyres but I am a hack and scared to launch with the std gearbox so was only getting 2.2sec 60ft times. Will go back one day with 20psi and when I have a reasonable set of tyres and I am ready to lunch my 205,000km old std gearbox :)
Be a men, do da right fing. Launch that sucker lol
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
