If they're like the 4-9 the exhaust manifold they link the outer and the inner pairs of exhaust ports ie 1+4 aqnd 2+3 .
That way when the inline four cylinder goes through its 1-3-4-2 firing sequence it alternates between each side or outlet port of the exhaust manifold . The idea is that each cylinder vents into an area of low pressure because the last vented into the other side of the manifold and turbine housings scroll . This way more of the exhausting cylinders thermally excited exhaust energy (gas velocity) is screaming into the turbine blades .
Where you have a single outlet manifold and single passage or scroll turbine housing all cylinders vent into the common manifold/housing meaning the average pressure inside it is higher , because of this each venting cylinder is venting into an area of higher pressure and can't exert as much energy or gas velocity into the turbine blades because of the lesser pressure differential .
You can reduce the pressure in a single scroll system by increasing the size of the turbine housing but you lose turbine response by doing it .
Twin scroll systems allow you to use bigish A/R turbine housings without much of the turbine lag so they are a win at low to medium as well as higher engine revs .
Interestingly the Americans have come up with a torque number that they try not to exceed because if they do they bend connecting rods and break pistons - on std 4G63T engines anyway . I think its something like 400-420 ft/lbs they try to torque limit them too and go looking for cams revs and Hp numbers instead .
Personally I like the idea of those sorts of torque numbers at 3-3500 revs because it makes a Lancer with AWD and sort of short closish ratio gearing a slingshot off the line and they pull like buggery in every gear .
My 6 is mechanicaly std ATM but after the first time I chased a bike off at the lights and nearly ran over it I learnt not to do that .
A .
Um BTW , a correctly phased inline six cylinder twin scroll exhaust manifold links 123 and 456 . This is because an inline sixs firing order is 153624 and to alternate evenly between exhaust events thats how the manifold has to be . Its also done this way with parallel twin turbos on an inline 6 for the same reasons .
12cm evo X housing, now were talking business.
I think a call to GTP is in order... I need more info re reverse rotation turbos. There has got to be a reason why they are able to use SL2 and 20G wheels in the reverse rotation housings..
Need to get back on topic, poor Kando!
Try the evo forums mate,
They love those FP turbos !
Good mate of mine is about to put an FP RED onto his V, will be interesting to see the outcome.
At this point thinking around 300WKW with fairly reasonable response.
Will post back when we have data.
those are the ones
massive fan of trust
have had 2530 with a single 20g
WOA, YOU!
How did you find the 20G on power for a 6?
How much power did it push? And what exhaust wheel were you running with what size rear housing?
Sorry for the attack, just trying to gauge as much as I can on the 20G topic.
Thanks,
yea i have heard of people running 270rwkw
but on this engine ( tired a bit... blowby)
the most the poor little sucker could muster was 250rwkw
ran 114mph in a 1650kg car so sounds about right
in the zed it made just over 520rwkw with two of them thorugh a auto( allegedly)
felt dam fast the zed
youve not seen the results from Simon? lol
Im tempted to go the kando SL2 20G but Im not sure if I should try something outrageous and go for an evo twinscoll housing to match.
Your results do give me some confidence that it would be an epic turbo for the RB25, 250kw@12psi and 12psi by 2300 would probably be no more than 1000rpm worse on a 2.5L (more like 500 I think) and would easily push the same figure with an extra 2psi. Evo dudesssss push these things to 1.8 bar NO WORRIES (actually they do that with the stock 16g too).
Majorly considering a simple T3 IW 8cm job when its available.. Kando = winnarr
Love the sound of these turbo's, very impressive!
Finally a turbo that bridges the gap between cheap ebay turbo's and expensive jap ones!
My mate put me onto this thread, but I'm still unsure of which one I should run:
rb30det with stock (healthy) internals....would be happy with 260-310 responsive kw's.....going in an s13 skidder (100% track car)
td06 or t67? 20g or 25g? 8cm, 10cm or 12cm?
If your that excited maybe just read through the thread.
The t67 with 10cm rear that Simon is running would be a great turbo for an RB30 although you will make more than 310rwkw pretty easily. Will you be running an aftermarket manifold and external wastegate?
Just a quick question, as I have recently purchased one of these turbo's (Identical to SimonR32)
One of the first things i noticed after taking it out of the box, was the fact that there was a small amount of shaft play. As in, you can move it from side to side (not enough for the blades to touch the housing) but they come very close.
So my question is, is this sort of thing normal for this type of turbo? SimonR32, was this the case with yours?
Or should I be sending it back for a replacement...
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
