That one I told you about in Japan is still for sale
http://page17.auctio...tion/v228047993
But cant help you out with the requested money tree :cheers:
Damn, and I thought everything was coming together.. I was brewing up a storm after lunch and I thought I\'d have some wicked manure for the money tree.
I'm thinking this 68HTA onto GT28 concept might be exactly what I'm after. My motor is a little knock limited and doesnt like lots of boost, Mark did say that this compressor is aimed at the production type guys with limitations.. Especially the impreza boys who struggle above 17psi. That might suit me a lot.
Im thinking that the GT28 might turn the HTA a little quicker than a TD05H will, and get some more shaft speed where I need it. That will probably see me cap out a little earlier than the compressor is capable of doing but I am honestly not chasing 300kw.. If I could get a flat out 240 at a reasonable PR I would be very happy.. Mark sounds confident and as always Stao is willing to do a smashing price on the mashine work.
Need to sleep on it and bite the bullet by friday at the latest.
Hmm how much for the FF? one of the only 20's not to nose over up top was your getup with the old cam timing, i reckon this manifold was the key.... im looking for a c33 laurel to piece together atm... rb20 with l2 on cane sugar of course.
Looks like I cannot PM you.... Honestly I'm sure we can work out a deal where it costs us both nothing ;)
But it could be a few months whilst I collect parts which I have thrown out / lost / sold etc, get new piping and a GTR BOV. If you aren't in a hurry you're on!
I stumbled across an RB20 inlet manifold converted to FF item. Something like this should help with your lack of torque mid range yet also shorten piping by a whole heap.
http://www.skylinesaustralia.com/forums/topic/390599-parts-for-sale-need-to-go-have-a-look/
If I was going to do anything to the inlet I would be interested in just modding the std inlet with a wider twin throttle body off an L98 or LT1
But I dont think I have ever read anyting about the std throttle being a restriction so not sure of there is anything to gain from going to smaller twins to try and sharpen throttle response and flow to the plenum
http://www.skylinesa...go-have-a-look/
yeah bad idea, the distribution gets all screwy, too much cylinder triming needed to even out the fuelling.
http://www.ebay.com.au/itm/320823909317?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2182wt_1270
found this mild steel top mount manifold. i know the SS manifolds tend to crack and warp from heat and weight. i was wondering if these would be any better as they are mild steel and a cheaper option than a 6 boost
http://www.ebay.com....#ht_2182wt_1270
Read the last few pages and the below link. We have been discussing those exact manifolds.
Ebay steampipe manifold thread
I think the general verdict is they are worth their money.
yeah sorry i hadnt been on here a while and just after i posted it i saw the thread sorry guys ignore it
and yeah i was going to stick to the td06 and stay stock mani for the cost reasons but for the money on one of those manifolds i think id rather go the t67
Being brutally honest I would go one of those manifolds regardless of the option, but thats just me.
Pick the outcome you want, but id say use one of those manifolds for sure.
thought id post the progress of my 10cm sl2 20g. Getting there slowly. mucked around with the water lines today. Just need a fitting for oil feed to block, finish intake and cooler pipeing then i can send it of to get a dump made. Soo exited hopeing for 300+ atw on E85 with killer response.
Whilst the gate looks great mounted there im worried it will crack eventually. Isnt that the weak point where the manifolds crack without cutting a 2 inch hole?
I think you are well on your way to the 300 club. :thumbsup:
hmm im abit worried about the manifold long term also. Ive had the pipe and gate flange glowing red with the standard turbo afew times, no cracks yet. fingers crossed it lasts longer than the motor will haha
Edited by dori33
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
