i've searched and everyone says they're a waste of $$ on a RB25, with zero gains
Really? OK, I stand corrected. Everything I have ever read suggested that the RB26 and RB25 were the most responsive to cam gears, (a friend played with custom inlet cam gear on a NEO and got nothing from it...but an adjustable cam gear worked well on his exhaust side)...and RB20s respond well, but not as well as its bigger cc cousins.
I have read that cam gears were a waste of time and money if you were running Poncams. But...can't say I have paid too much attention to it the last 5 years...it used to be a golden rule
I quickly discovered a page or so back he hates one of the best engine makers in the world - based on that lot I'd not really expect him to have the kind of appreciation or understanding of optimising engine efficiency needed to treat as an authority on the topic.
i think it was Trent who mentioned something about cams being not worth their $$ on a RB25.
got a dyno sheet of this? if there is proof of gains i will get an exh cam gear.
Lithium, you referring to me about my honda post last page?
Cam gears , not cams! I have not heard of too many RB25s not responding well to cam gears on std cams.
As for dyno sheets? Hell man, we are talking around 2004-2005 when he made a custom inlet cam gear that could be adjusted as part of all his trial and error. It was all for 0 anyway as the setup worked best set at 0 and the exhaust side retarded a little using his off the shelf HKS exhaust cam gear
It all depends on the set up some rb engine greatly benefit from cam gears some not so much personally I think it would be a decent investment cos lets face it if your chasing power you have wasted money on worse things I know I have
Gone through the last 40 or so pages. Am I imagining things or are not many people running the TD06H-25G? I know heaps are running the 20G.
I am looking at this turbo http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-Inlet-TD06H-25G-T3-V-Band-10cm-AR73-500P-/270913941567?pt=AU_Car_Parts_Accessories&hash=item3f13bab03f
Im not a guru on turbos so I thought I would ask here. I want great response since ill be doing track days, am I looking at the right turbo? Chasing around 300ish kw.
I also noticed the two types, water cooled and oil cooled, which is better?
If you were looking for a easy 350KW on 98 would it be better to go as TD06SH 25G 12cm or T67 25G 12cm?
Whats the power difference between the TD06SH and T67?
I know the TD06SH has the 58.8 and 67 turbine wheels but would it push it enough to make it worth the lag?
sorry, it was a typo, i meant cam gears. i'm still against them until i see proof provide decent gains.
it will not be a decent investment after the $$ you spend for your tuner to tinker with them and to set them up especially after all the work and only to find maybe 1-2kw gain (if your lucky)? Lol
+1 i didnt notice any gain from my cam gear install
:yes:
You answer your own question the h has a bigger turbine wheel I had the td06h-20g on my 20 and was seeing full boost at 4200 18psi so it's only a few rpm if you want bigger numbers
:yes:
Haha depends if your tuner try's everything and not just turn up the boost. I don't think it wound be worth it on your set up because the turbo is already working very well. From what iv heard you can get more mid range and bring the turbo on faster that why I thought it would be worth it not so much power out put.
i've still yet to see a dyno sheet where it provides a gain in response in the mid range.
i've seen some results with cams installed but not with just exh cam gear adjustment only.
feel free to prove me wrong, i am skeptical until i see evidence that it works.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
