Hey guys, got a bit of an "oddball" setup going on, am doing a remote mount turbo. Engine is a VG30DE 10.5:1 comp, and am looking at a TD06-20G as the turbo. Will be running Water/methanol with no IC, but will only be running 7psi for the first week or two. Would a TD06-20G be too big? maybe choose a smaller exhaust housing then usual?
gday guys, thought id post my results from using one of these turbos
i have a tdo06 20g sl2 8cm rear on my rb20
turbosmart 40mm wastegate
550cc denso injectors
bosch 040 fuel pump
z32 afm
splitfire coilpacks
ebay spec front mount
3inch exhaust
Nisstune
still needs a little tweeking like a new CAS, decent front mount and cam gears are on there way.
cheers - trent
Hey mate, I dont think it would be too big. Possibly the smallest id run to be honest.
Yet I dont have any first hand experience with a remote mount, maybe it needs something different.
GL
bosch 040 fuel pump
z32 afm
splitfire coilpacks
3inch exhaust
Nisstune
cheers - trent
Wow plots so much different to mine, absolutely nothing happens till 4k then bang, it gains 120kw by 5k..must be fun :D
did you find out if that ring was missing in the gate??
yeah she up and boogies after 4k lol
im looking at jumping on the e85 bandwagon ;)
nuh it wasnt missing all good, is your dyno sheet in this thread mate?
edit; found it, very impressive mate :)
Edited by TJR32GTS-T
+1 more specs on the SR above please, and
JEZ: specs on the motor you recently tuned with the 20g internal gate please.
Its a stock rb25 Running stock manifold. Td06 20g 8cm 21psi on 98 octane pretty aggressive tune.
No vtc yet.
Has since made up a 5 bolt rear housing and boost pressure is safe and stable at 14psi. Should help with flow too.
Retune on 18psi once he gets car rego'd
This is a great turbo to stop getting defected coz it looks like a stock RB25DET turbo with all the japanese on it. Im also loving the fact that you can get about 300kw stock using this babe. Thumps up fellas for finding this masterpiece
8cm will be perfect for you, but if you're only running 7psi, you probably won't get much power and may be laggy.
what is your goal - response or outright power?
No vtc yet.
nice, i reckon it will be perfect streeter with response and 250-260~ rwkw and can match the similar turbo from hypergear.
i am here. :nyaanyaa:
should be getting the car back tomorrow so fingers crossed for no issues & good results...
Will be pushing it up to 15-17psi and yeah outright power is the goal.
go the 10cm.
the na compression will help spool it up
The below picture isnt a perfect example as the spreadsheet is the combination of my car on two different dynos and two different tuners. The dynos read about the same, if anything the dyno that produced the 8cm result read a little lower then the 10cm dyno. The tuner that did the 10cm tune was not as good a tuner as my current tuner. So that obscures the result.
But even so, I think it paints the correct picture as to what happens when you throw too big an exhaust housing on a car. Unless your car is choking on its exhaust gases, going to a larger A/R housing is a pretty risky way of trying to get more power. Especially with a turo mounted well away from the head. The exhaust gas would not have the same amount of energy after its gone through piping and cat/mufflers etc
If you want more power look to try and get your inlet temps as low as possible, back pressure from exhaust as low as possible, pressure drop in inlet as low as possible etc. Then have a look at your
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
