Yeah Unique automotive in villawood, he tuned my friends turbo excel, well tried to atleast. They told him to tune it on no more then 10psi, but he ended up incorrectly setting the boost controller to 18psi. Was also overheated on the dyno 3 times.
Lol maybe that is why they are so 'Unique'.
Sounds like another workshop to steer clear of.... Good tuners and good workshops are becoming a bit of a rarity these days.... I had a bad experience with a local workshop recently and will never take my car there, nor will i let my mates take their cars there again... Word of mouth goes a long way! :dry:
On the flipside, word of mouth also goes a long way with GOOD tuners and workshops
I would think taking that centre bit out of the manifold is a bad idea. because the turbo isn't centered you have 4 cylinders of pressure on one side pushing against 2 from the other makes for uneven flow pattern. If it turns out to be the culprit piss it off and get a hybrid topmoumt I'm dying to see how well it would work :P
Failing that my guess is you have fuel delivery issues, but it's just a guess..
Dori34 i doubt it is your manifold.I got mine tuned last weekend and was worried the manifold was going to cause turbulence problems. My whole top half of the splitter is gone. Silly me put the 20psi spring combo in my gate assuming it might just run under the target pressure(so i can use boost controller to up the pressure 1-2 psi and ramp boost up abit quicker) but ended up going to 22psi in the top end. the least power it could make was 300atw with very minimal timing and fat AFRs. That is on caltex eflex though. going to see Trent this w.e for a touch up and il ask for a dyno print out and il post them up.
Your not getting a bad name. The quality of your work has not been mentioned at all.
Putting a gate on the stock manifold wasn't guaranteed to work, its nobody's fault if it didn't. It doesn't matter how well you did the job, it matters if putting a hole in the collector of a divided manifold and a gate within a few inches of it will create turbulence.
See what happens anyway.
yeah gate on manifold should be fine, it was just removing the splitter I was unsure on,,but as it turns out its still there anyway...so my point was proven invalid already..
secretly I was just trying to talk him into the hybrid topmount though cause I want to see how it goes..
OMG am I seeing ghosts or what- just how many doris do we have here?? One talkin to the other.. Confused:S
TBH, i wouldn't be suprised after the last issue with my "boost issue" which was just the EBC set incorrectly.
the boost plot is only for the 1bar run, but from what i saw, the 1.2 and 1.4 bar runs was just flat line like the 1bar, no issues there.
OH NOOOO
Hey dori33, what's done to your car and any Dyno sheets? I wanna see where the restriction is how it looks ok a Dyno if your maxing out a Mani.
Guys, please don't doubt the manifold, it's been done before and they've have made 280-300rwkw on this set manifold setup, Blake has done a good job. he's done a lot of work for me and I appreciate all his help
Thank to Jez you legend, looks like another silly mistake done by my tuner.
I think I'm gonns book it in with you earlier cause I can't wait any longer. Speak to you soon mate.
im just having a look to see if the haltech works off kpa absolute or kpa.
ill send you the tune back with the overboost raised, let me know if it still cuts out, but obviously dont go thrashing it as the tune isnt finished for high boost
Not so much a bad name but I loose work over people saying the manifold don't work it does work and it's proven as jez just stated boost cut wasn't changed for high boost. If the manifold wasn't working it would be spiking seems every time dori has a boost issue the finger gets pointed at the manifold and it effects my clients Thinking my product is shit
hey rondofj can u try one on a hybrid manifold, looks like doris car is sorted damnit >_<
I mean YAY!!! :banana:
At the mo im just about to come out of a 6 month hibernation in a weeks time, but hopeful of dori's results too as thats whats Im intending to do.. :)
On an unrelated note Jez, what is the difference between the PS1000 and PS2000 based on a setup like Dori's and like mine? (Bit of a Noob question i know...)
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
