jez has raised the boost cut higher and i will be testing it tonight, fingers crossed this fixes the problem :)
Man i really hope that's what it is!!! Will be a silly mistake if it was the reason!!! :wacko:
im just having a look to see if the haltech works off kpa absolute or kpa.
ill send you the tune back with the overboost raised, let me know if it still cuts out, but obviously dont go thrashing it as the tune isnt finished for high boost
its absolute pressure :thumbsup:
Internal Input Sensors
MANIFOLD ABSOLUTE PRESSURE (MAP)
Rated to 150kPa (up to 1.5 Bar or 22 psi boost)
External Input Sensors (supplied at extra cost)
1 Bar -100kPa to 0kPa (Naturally Aspirated)
2 Bar -100kPa to 100kPa (up to 1 Bar or 15 psi
3 Bar -100kPa to 200kPa (up to 2 Bar or 30 psi
4 Bar -100kPa to 300kPa (up to 3 Bar or 45 psi
5 Bar -100kPa to 400kPa (up to 4 Bar or 60 psi
Not so much a bad name but I loose work over people saying the manifold don't work it does work and it's proven as jez just stated boost cut wasn't changed for high boost. If the manifold wasn't working it would be spiking seems every time dori has a boost issue the finger gets pointed at the manifold and it effects my clients Thinking my product is shit
Become a trader then you may have a leg to stand on imo
As for "your" product. It is just a copy of what dozens of others have done
So they aren't saying "your" product,?just the design in general is not ideal
So untwist those knickers lol :)
so i tested it this morning with Jez changing the boost cut higher, tested in 2nd up to 6800,i did not notice any power loss at all, so far it's looking promising.
i also found out my tuner set my high boost to 24psi when i strictly asked for 21psi. hmmm
Yeah and your boost cut was at 23psi wasn't it? From the post from Jez? Which may explain why its dying in the ass when its on full boost? Sounds like your on the right track so far, cant wait to see it all sorted!! :D
yeah me too man, been to many dramas/heartbreak/headache the past month.
dropping it off to jez next weekend, woo
Next weekend eh? Sounds awesome! :thumbsup:
I REALLY hope i dont go through this drama when mine gets tuned soon... Ill let you know how i go with ECU choice etc, should be happening very soon!
Hey mate, it definitely is a looonngggg thread with lots and lots of info, yet everything you want to know has been covered many times over.
Just to recap for you: we are only considering the TD06L2-20G 10cm or the T67-25G 10cm on an RB25 in all scenarios. The IW housings are a crap and arent stacking up even when trying to improve them.
You will need to run an external gate on an RB sized turbo, we recommend the tial 44mm gate as per SimonR32. If you are running a 4 banger you can go to the TD05H-18G in the SR20 spec housings, these do work and net around the 240kw mark.
For your goal of a zippy 270kw you should be looking at the TD06L2-20G 10cm with a small spacer and hung off the standard manifold. I recommend you hang the gate off the rear housing.
Alternatively, Hypergear has an excellent internal gate option called the SS1PU. It does not have the same 'scope' as the 20g (20g looks like it could be stretched to 300kw) but it does have the ZIP you are after.
Please have a read of this thread start to end, you will understand more than what you need to know to make an informed decision.
Thanks mate, going to try and get through it soon.
I have decided though the TD06L2-20G on the standard manifold will be the best for my application i think, can anyone reccomend somewhere i can get the housing modded for the gate? Dont think anyone local to me would be keen.
Send it down with the wastegate flange, I can do the same mod as Artz has on the rear housing if you like. :thumbsup:
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
