I get my content woes/information down a short grape vine from the very top of CAMS hierarchy. Not that it changes anything, but like I've said before we all form our opinions somehow.
Not a good source for information imo. Too many kickbacks from the race fuel industry perhaps?
Trent has tuned countless times with Eflex and C16 with little difference in performance or safety. I know which one I would rather pay for in my daily...
My kando/kamak T67-25G 10cm finally turned up today after a few delays, Compressor housing hits rocker cover so RB20's will go on, weld V-band and wastegate off exhaust housing tomorrow.
RB25/30, fresh rebuild
stock rb30e piston & rod
stock RB20in RB25ex cams, No VCT
ebay stainless manifold
Freddy plenum
80mm throttle
Tial 44mm MVR
Apexi Power FC
Splitfires coilpacks
Nismo 750cc
Modified twin feed rail
Twin bosch 044 pumps
Surge Tank
E85/Eflex fuel
Previously GT3076R :yes:
Your probably not wrong, I wont go there for now. Hate 'he said she said's', especially on the net lol. V8s did end up going E85 though, but with the guaranteed content CSR shit.
I have heard reports that eflex is fairly consistent at the e70 mark.. But I just cant get past the fact its a varying content fuel. Like I said in the HG thread, I fully believe in it as long as its used with a content sensor.
Once it properly rolls out in NSW and is available everywhere I will honestly be buying a flex capable ecu and getting it tuned on that :)
Freddy plenum
80mm throttle
Tial 44mm MVR
Apexi Power FC
Nismo 750cc
Surge Tank
E85/Eflex fuel
INSANE
Hi guys
After a little help and thoughts on the set up Im thinking of changing to. Its an SR20DET in my 180sx currently running a 2871r 56trim .64exh with HKS step 2 264/264 cams and supporting mods, it makes 268 rwkw on 18psi tuned on E10 100oct.
Im looking at going to the Kinugawa TDO6SL2-20G T3 V band 8cm high mount with Tial 38mm external gate.
So a few Q's
Will this get me close to 300 rwkw on 18-20psi?
Should I look at the 10cm housing or stick with the 8cm?
Will the 38mm gate be big enough on an SR?
Im keen to keep full boost of 18-20psi around 4000rpm.
Thanks for any input.
Cheers
Edited by slippylotion
Found a cheap Evo turbo td05-16g I can get 2 for a catch can would these be any good on a 26
I have a twin td05 kit off a rb26 , in memory it made close to 400 rwk and ran a 10sec quarter , I'm about to put one on a rb20 , hoping to see 200rwk
Is there a difference in sizes between a T2 8cm housing and a T3 8cm housing?
I know obviously the T3 flange is bigger but does this also mean the total volume is also bigger. So is a T3 8cm sort of the equevilent of a T2 10cm?
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
