Worked out a deal with him, I send the CHRA back he fits a new turbine wheel, billet comp wheel, balances and posts back to me for the price of the billet wheel. Not completely satisfied but that's the best Im gonna get out of them..
that is actually a very good outcome! look forward to back to back results with the billet wheel :thumbsup:
Ok so the Troublesome internal gate td06 is now sorted. With a very consistant 14psi low boost made 260kw. And hi boost made an easy 280kw without finding the limits yet. Have a slight issue with the ecu dropping timing at exactly 5000rpm every power pull. Have to study the log file and see why. Rpm and all other signals are fine but it pulls timing for a split 2nd and causes a missfire
But it's not an internal gate turbo anymore :blink:
Clutch is in fellas, feels gooooooood....can be a bit edgey on take off, (trying to drive it with my chunky workboots on was tricky) but after that all is good....very light pedal but when it bites it bites hard... now planting the foot in 2nd is alot more exciting than it was.....
I got a rolling video here for shitsngiggles, soon as i figure out how to get it off my phone :angry:
Anyone else noticed there's funky new emoticons...
being an 18G i would say so, its probably calculated engine power.
still cool tho. if trust can use T3 to T2 adapters id say it works fine. Which would give me confidence to do exactly that and put a 2871 on a RB25. Budget GTRS.
ARTZ what clutch did u get man? i re read 10 pages and couldnt find it. You must have said it in the HG thread...
Correct. And he is very annoyed at his wife for making him get the internal gate turbo.
He worked out he spent around 22hours trying to fix the internal gate to perform how it should. Then i gave him a 38mm ebay gate that he welded to the housing. Worked perfectly.
We all told him
ROFL your secret is as safe with me as mine is with you :ph34r:
Wish I could get my car back to you soon man. Things will be a little tight for a few months, the S13 was our last luxury for a while.
Can you do a run with road speed instead of rpm? Are you sure that rpm scale is correct?
Rpm is a roller speed ratio that i have to input rpm It matches the log from the Nistune. When i get back to the shop i will take a pic with roadspeed
Why do u ask?
@ STATUS
Just a quick question. The SR's you have tuned running a kinugawa tdo6sl2-20g are they an 8 or 10cm rear and internal or external gate? I bought the T3 external V band with 8cm rear version and my mate Pete Leibig is tuning it. Just wondering if I should change to the 10cm as I want to reach near on 300rwkw on 98oct and over that on E85.
Thanks
@ STATUS
Thanks
i know peter very well, legend. If he wants to talk about it when he has car on dyno let him know he can call me anytime 24/7.
8cm will do it, 10cm will do it easier and lower boost (about 18)i prefer the 8cm.
The internal ones are plain JUNK.
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
