Because the boost falls over at the top it seems inconsistant with boost creep as creep should keep climbing all the way to redline. But 38mm is right on the limit.
What im saying is use te boost controller to try and run 18psi solid from 4 to redline. If he had not control at all with the boost then the boost controller lines are back to front
I see what you mean. Ill get it sorted one way or the other soon.
Once i sort it out i hope it comes on earlier too.
So i wouldnt get the results I am after with that turbo?
For an internally gated turbo you would definitely get a better result from a Hypergear :)
For your power goal of 230-250 I recommend you get a Hypergear highflow, it is a simple rebuild/respec of the standard turbo that will get you the results your after.
That being said, it will also bolt straight back on where you took it off (stao will provide you with the extra bits needed to make it direct fit). Its also cheap, only something like $960 delivered and ready to bolt on.
Confused reader here. I have a pretty much stock R33 S2. All I've done so far is 3" from turbo back exhaust, mounted an ARC return flow intercooler, installed a cheapy Drift pod filter and grounded the boost wire. I've also installed a Walbro fuel pump. I'd love to get more boost happening and understand I'd need to get a different turbo. Hypergear sounds like it could be for me as it's direct bolt on. Then get a nistune board installed and get it all tuned on the dyno. At that state, what HP or KW do you guys think I'd getting? I don't have plans to go as extreme as some guys here, God bless them, so think a high flow and nistune and I guess new coil packs (will I need new injectors too?) is about my end game, plus at some point replacing my stock shocks.
My advice is to get the ECU first. Also, if you are considering buying a HG turbo, Stao can give you a great deal on an Adaptronic plug in ECU. Something to think about given you have an R33, so the NIStune will take some messing around. The Adaptronic may represent better value for money. Perhaps look into it?
Then, it depends which turbo you end up getting from HG as to what HP you can expect and whether you will need injectors. If you go a simple highflow, stock injectors mayyy be able to do the job, perhaps with a bit of help from an aftermarket fuel pressure regulator. They will be very close to maxed in any case. However if you want something capable of say 250rwkw, then you're probably going to have to do injectors as well. I'd suggest talking to Stao about what you want.
Edited by Hanaldo
Sounds good until the adapteonic ecu is $1500 plus tuning instead of the $1350 supplied fitted and tuned including z32 ecu for nistune
Not if he buys the HG turbo. Stao quoted me $1040 delivered for the Adaptronic.
Plus tuning. I agree it is a good price but nothing can beat NIStunes for cost.
Tis true, the NIStune is a good option I agree. Just food for thought.
How much would you charge to do the Adaptronic? I was quoted $650-$750 to install/tune my Link plug in. Also have to factor in IAT sensor. So if the Adaptronic is similar, then you're looking at what, $1800 installed, tuned, everything? If the NIStune is $1350 tuned, and the OP decided he wanted more power and needed to get the Z32 AFM as well, that makes it between $1600-$1800? Depending on the price of the Z32 as well as installation, etc.
And that's only if he decides to get the Z32 done at the same time as everything else, if he changed his mind later and needed to get it done then that adds another $400 or so for a retune? Whatever way you spin it, the NIStune is probably going to be the cheaper option. But if it's only ~$200 cheaper...
Edited by Hanaldo
Be it myself Id probably take up the offer on the HG and adaptronic, as it takes away another expense (AFM) as stated and one less thing to compensate for when making intake pipes and all that crap.
Id personally like to own an R33 which had a HG H/F, adaptronic, TBE, pump, fmic. Id leave the stock injectors in there and run it at the quoted 15psi. Should go really well.
U are spot on. Thats why i try to convince most customers to do everything at once then to keep adding parts that require a retune. Costs more up front but saves alot down the track
That's exactly what I'm trying to tell myself about getting the Link installed now, rather than later. The soreness of the wallet makes it a bit hard though :glare:
Except when the minimum boost it will run is 18psi. Ask Mitcho. I dont feel its safe to try max the injectors out and leave them running like that.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
