240rwkw from a 3071 is not surprising, Garretts are a mixed bag to begin with.. Always hit and miss on results.
A Hit 3071 is 290rwkw, a miss is 240rwkw. Hit 3076 300rwkw, miss 270rwkw.
I want to know myself! One way or another it's pretty sweet, and no doubt the 4deg retarded camgear has a fair bit to do with it though the manifolds can't be hurting, and the turbo clearly needs to efficiently flow up there.
Simon - do you know of anyone with cams and a T67, or do you have any plans to do it yourself?
I honestly have to say my opinion is the combination of the 6boost and a healthy motor.
Simons motor does not show any signs of sloppy valve springs which I think are the main contender in limiting an RBs power development.
I ditched my RB for this exact reason, I knew it was fine as a factory motor but also knew it was anyones guess how it would handle over 300rwkw. I am, however, dubious of the benefit of the forward facing plenum.. Yet wont knock it either.
The different size/length runners make a reasonable amount of difference with this kind of thing and sloppy valve springs no doubt come into it too - but peak power for a factory RB25 by definition of Nissan is 6400rpm, and a car with stock manifolds and pretty much any turbo will make peak power around those rpm. Thats where mine makes its peak power, as with gazillions of others I have seen - I am pretty sure a T67 will be no different.
You're going to need some pretty serious mods to get a 1JZ revving like that ;)
OH YEAH?!?!??!!?!11!! Dont make me huff and puff and blow your house down!
Kidding, well see Mr Duracell lithium ultra :thumbsup:
I have a few concepts Im toying with at the moment, yet my primary objective is to get this thing on the track as quickly and as cheaply as possible WITHOUT the use of the factory twins.
No doubt the FFP has changed the motors dynamic VE, yet I am dubious to what extent and effect. Yet I honestly am no expert in this sense either.. I just HAVE to point out a healthy motor to begin with, thats a major factor in my eyes.
This is the only graph I have seen with a Kinugawa T67-25g with cams;
Blue = Stock cams
Red = Camtech drop in cams
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=294805
No plans for cams, I really don't see the need... Turbo appears to be maxing itself out and I have more than enough power throughout the rev range :)
yeh me too :) where you getting yours tuned? ill most likely be taking mine to STATUS.
i was going to status, but ive chosen a different tuner, the guy im going to was recomended to me by a friend, he tunes thier GTR track cars, and also an aus distributor of KAMAK turbos.
Nice, was that on pump gas? The factory setup is pretty impressive, going by that lot.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
