Yeh the "hilarious" comment was directed at the turbine blade being supposing replaced/fixed.
Was such a pain to get him to do anything, I was emailing him every 3-4 days just to keep things moving. the turbo was sitting lost in his factory for a week before I emailed him and then he found the thing.
I can only figure all the wheels must be like that... He can't have cleaned it and thought "she will be right" when it obviously took you time to look the first time and were going to check again.
It's a $99 (retail) part... I just can't understand the reasoning for cleaning it and giving it back when it's so cheap to replace.
Just a thought, it had several cracks before yeah? Does the new/washed one have multiple ones, I can only see one in the photo
I know it's totally irrelivent here, so just ignor it. When I was having a look at an old jet engine I looked at the turbine and it had dozens of little cracks all over it. I said to the tech that this must have been a spare parts engine. He turns to me and says , nah she'd be sweet like that and fly just fine. He went on to say people wouldnt believe that state of some things flying around.
From someone with turbo building experience, is a crack like that a fatal flaw, that will break in a matter of time? No doubt it's not good business practice what you've experienced battery.
How longs shipping take with kando? I ordered my T67 2 weeks ago and still nothing, 3 days after I bought it I asked him if it was sent and he said hes still making it? Why list something on ebay if its not ready to be shipped?
Found out my 2xTD05's were sent to "Austria" when they hadn't arrived after 3 weeks. That said, Eiji sent another set which turned up about a week later.
my bad (damn small phone screen :P)
So is it a crack or just a casting imperfection? Pretty disappoininting. Maybe I should pull apart my 18G and have a close look at it
Crack. You can see light through it if you hold on a certain angle.
I hear you Simon and I really want this Kando stuff to work out cause im a fan of bang for buck gear but it just seems like the more I deal with them the worse it gets...
It has more than 1 crack, honestly looks similar to the old one but I can't be sure. It does seem like it could be a result of the manufacturing process because the wheel is quite thin around that area but to me it just looks like a weakness and a fault waiting to happen.
The few experts i have talked to about this(without seeing the turbo) have just said flat out that its no good but i think ill have to take it down and get them to have a good look in person.
Interesting... I hope that he hasn't just f**ked you over because that would not be very professional (or good for business)
Somebody should email Eiji a link to this thread. I wonder if the amount of business he would lose would bother him.
This sort of thing is putting him into the cheap chinese basket when we previously considered Kando to be a good value item. Its now looking like their QA is dropping off something massive, and has me worried.
Whenever I consider a new setup for myself or a friend, I always consider a Kando product first. But I am not liking this change.
MAYBE, just maybe, the reason why QA seems to be dropping off is attributed to the fact Kamak are selling their own product (for more than double what Kando do).
So I took the paper weight down to a few turbo specialists, first place said "its dodgy but should be okay" I asked if they could supply and fit a new wheel they were like no we only touch our own stuff. Second place was like "No way can you run that shit it will explode" they would supply and fit a new one for around $400, $200 if i supply the wheel. Both places were obviously very bias and happy to jump on the "shit china turbo" boat...
Also compared pictures of the old one and now im pretty sure the turbine wheel has been replaced cause the cracks look different. I'd say they are all like this but whether or not its an issue is what im not sure about....
i guess currently it aint damaging perfomance as such say ure had been likt that from the start it lasted how long ?? ive got t67 aswell cant currently check to see if mines the same.
Im thinkin personally ill purchase some spares and get it rebuilt here if something goes wrong
Also i posted few pages back saying id have my results up soon well it been delayed a bit.I smashed some valves so back of with the head going metal headgasket this time looking around 300 this tune then looking for more power later down the track with e85 and water meth
Smash it back on and just run it :) The worst that can happen is you loose the rear wheel and it flys out the back of your exhaust or gets stuck in the cat
To make you feel better about it, it's not a load bearing surface (I think) and if mine is the same they can take and beating haha
Finally got a reply and this is the result
Hi Mark,
I check with our delivery department and was replied there seems problem on the T67 turbine shaft and we could balance it.
We are still trying to solve the problem.
I am still in business in korea and will be back tomorrow afternoon.
I will double check the situation for this turbo for you.
By the way, if the T67 turbine wheel can not be solved, could you accept the bearing system to TD06SL2-25G type like this ?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-4-TD06SL2-25G-T3-10cm-V-Band-External-450P-/280868632390?pt=AU_Car_Parts_Accessories&hash=item4165133746#ht_2463wt_1185
it can go with anti-surge inlet as well.
The both wheel spec is same.
All the difference is bearing system.
Sorry for waiting and inconvenience.
Regards
Eiji Takada
jez hates anything in large quantities. boost, timing, power, you name it.
except cock. he loves cock.
Hahahahaha.
Only thing i don't like is large heads on customers :P
I love big boost just not when u bring a 10:1 comp sr20 with 98 octane and try running 16psi.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
