look i dont go that way jez, but any customer with a big head is only going to hurt on the way in.
thats what i tell my girlfriend anyway.
Not to be rude but um... you just said said your GF has customers with big heads that hurt on the way in....
I realised after I posted that I left myself somewhat vulnerable there lol
Good pick up.
well it finally started but I could only find a crappy peice of tube to connect for the Idle valve and it kept kinking so it would barely idle. But other than that about friggen time.
Nice work! :woot:
Did you use the tie wire with that beanie, or just left it sitting there?
I dont know if anyone can answer this but will this (see link to what i have bought)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=270967679078#ht_2148wt_1185
Work with my turbo like this (has the V band in the middle not with the bolts)
http://img.photobucket.com/albums/v416/razor911/04022011611.jpg
This is a hard one to describe, but im confident its the right housing.
if you think about it, just coz the CHRA can be v banded, it doesnt mean you cant machine a bolt on housing to press up to the CHRA and work.
im pretty sure the kando CHRA's are direct copies of the MHI items, and many of the housings are direct copies of the MHI housings also. Yet these T3 10cm housings are definitely custom, and im sure it is them that is different to a normal housing and are machined to have the v band chra slot in and then have a bolt on piece press it in.
Simple logic to me!
Nice work! :woot: Did you use the tie wire with that beanie, or just left it sitting there?
I used a spring on the dump side of the turbo. The other side was awkward to get to the clips and I just wanted to know if the bastard would start lol.
Urt. Did u wrap the entire manifold or jus cyl 1&6?
Hey Jez, nah I did about 2/3 of the manifold, the whole Ext gate dump and about half of the turbo dump. I had to remove a bit on the manifold to get the nuts onto the studs onto the flange, I might fix it later but at the sec I just wanted to know if it would start.
I reckon I did alright for a "pen pusher" with soft paper handling hands as my mates would call me.
Edited by urtwhistle
Simple logic to me!
Good point. Only way to find out is take if off and inspect.
I took the POS for it's maiden voyage. and all I have to say HOLY S**T BALLS. These turbo's sound like jet engines with the surge slots and wow I didn't expect it to have masses more bottom end then my old turbo esp when it's bigger. MUST GET TUNE ASAP!!!!!
Awesome!! Can't wait to see the results of a tune, but glad you are happy with it... Love the spool sound, haven't heard a Kando yet but can't wait too :D
Thats sick man! I like that TD07 front cover, Im of the opinion a larger front cover can be a really good thing on a turbo that size/spec.
Looking forward to your results :)
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
