Hey Scott this aint the truck turbo thats staying on it, I only fitted the truck GT3782 for giggles to see if the bonnet would close and kill my curiosity. This is a Kando TD06H-25G with a billit compressor with TD07 comp cover and 12cm rear but like you, I'm also quite confident that it will flow more than enough through a 3" cover
Sorry if I came across wrong.
That 3" TD07 housing is a truck one im pretty sure. I was just trying to make a point that you dont have the same 3" housing dori tried. Dori's one was the standard .60 trust style 3" thingy that has had surge holes drilled into it. Yours is an actual surge ported housing (not a modified one).
Most trucks use surge ported housings, and its not a typical trust housing which is what makes me confident its off a truck.
All in all im sure yours will work mate, no need to worry at this stage.
Did another track night last night and turbo still going strong, ran 1.4bar and 515hp all night and didn't miss a beat :)
How many km's you put on it in the last 18 months Simon? It's def proven its reliability
Id like to know if Simons has cracks on the turbine.
Twice as curious to see if the 20g I buy comes with complimentary cracks lol. Logic says no, because the td06 and t67 are a different shaft and therefore cast (shaft and wheel are one item).
Viva la cheap Chinese rubbish.
You would think it would have let go by now if it did
Cheap but not so nasty
Edited by t_revz
I'd probably say around 5000km's. They would be fairly hard km's as most would be at the track, drags, powercruise motorkhanas etc. I have a work car that I drive most of the time.
I don't think that the cracks 'battery' has would cause the wheel to fail, they are not at a stress point (as far as I can tell). For all I know mine has been cracked the whole time as well
Sorry if I came across wrong. That 3" TD07 housing is a truck one im pretty sure. I was just trying to make a point that you dont have the same 3" housing dori tried. Dori's one was the standard .60 trust style 3" thingy that has had surge holes drilled into it. Yours is an actual surge ported housing (not a modified one). Most trucks use surge ported housings, and its not a typical trust housing which is what makes me confident its off a truck. All in all im sure yours will work mate, no need to worry at this stage.
Ahhh true that, and yeah your probably right about the housings now that I think of it.
Had my l2 20g off last weekend to weld an elbow to the outlet, mine didnt seem to have the cracks in the exh wheel like the 67s. Turbo hasnt done too much work, but it still looks and feels brand new with the housings off. Couldn't be happier (well i could if the car was still registered and i wasnt goin to court)
why no burnouts :(
I want burnouts damnit....
We got told just because there was a chicane doesn't mean it's a excuse to do burnouts, luckily for me I just put my foot down and it layed lines. Not my fault :)
Edited by SimonR32
just brought a Kinugawa Turbocharger 4" Anti-Surge T67-25G T3 10 cm V-Band. waiting for it to get here. just need clutch, 6boost, fuel system, gate, tune and plenum before it gets fitted... then let the fun begin! :woot::cheers:
Edited by boooooooooooooooooooostin
Just need 10 grand before I fit my $800 turbo.
Just kidding mate haha, should be a weapon! Maybe avoid the anti surge... Dori34 proved it wasnt so effective.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
