GTScotT Posted June 15, 2012 Share Posted June 15, 2012 To you guys using the supplied kinugawa braided lines, do I need to use some sort of thread tape on the line to fitting and if so what type? Just starting to bolt it all up today/tomorrow. They are AN fittings so they press together as your tighten them, with tapered ends. I havent used any tape on any of mine and all have been fine. Anyway so what's the verdict on the SL2 fellas..seems it shapes ok to an old HG or a 3071..but is it any better or worse, cause all in all the setup is almost as expensive.. I am yet to see any 3071s stand up AS sharp @ 3500 RPM and make 300kw mate, so I think your ahead. In my case the 3071 is a LOT more than the <$700 kando. If you buy the CHRA and housing sepparate its about that much cheaper then the $750 listed price ($560~ actually). The Garrett also doesnt come with the V band ring or clamp. The cheapest Ive found a 3071 for is also over $1300. Realistically the Hypergear is the nearest competitor for value but I think hes still working on his consistency as far as 20psi @ 3500 and a track stable 300kw (even on E85). I think the nearest equivilent HG to your setup wont take the punishment (heat wise) yours will. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6400627 Share on other sites More sharing options...
Lithium Posted June 15, 2012 Share Posted June 15, 2012 Has anyone done a GT3071R on E85? Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6400668 Share on other sites More sharing options...
Tommyd32gtst Posted June 15, 2012 Share Posted June 15, 2012 Hey everyone I am currently fitting a kinugawa td06-20g to my r32 rb20 on a hybrid performance high mount manifold, Just tring to work out how I'm going to do a few things, if anyone has done this mod befOre could you upload photos of stages of your build or just pics of engine bay with piping layouts, any help would be great just after a few ideas Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6400930 Share on other sites More sharing options...
RBert Posted June 15, 2012 Share Posted June 15, 2012 The TD06 will probably be very flat from 2 - 3 and get a fairly abrupt rush of power around the 4k mark. this part is the most tempting in saying that it will be mostly for street use with occasional drift practice for learning so the clear result has to be a td05. the last part however - This is all provided you set it up right. - i was thinking the usual fuel pump, injectors, coils, manifold, ext gate, afm, fmic, stock intake plenum (if anyone can convince me its worth buying a front facing for the rb20 go ahead ) and then a nistune..again if a PFC is worth the money for the 20 do explain. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6401191 Share on other sites More sharing options...
GTScotT Posted June 15, 2012 Share Posted June 15, 2012 Has anyone done a GT3071R on E85? not that comes to mind quickly. the only one off the top of my head is Mick_O, but thats a GTX3071.... thing is tho, which im sure you will agree with, E85 doesnt do as many wonders for MHI items as it does for garrett. I admit an E85 GT30 variant is always more interesting than its 98 comparison.. But the MHI range seems to be pretty efficient at running out of available flow before they need E85 to keep ping away. Thats a personal observation of mine anyway. That can be seen by comparing <300kw and >300kw 20g's.. the difference is notable but not mind blowing, keeping in mind ARTZ didnt have a full tune completed on 98 due to a slipping clutch, but the E85/added boost and no doubt lots of timing added more power in the same places. The delivery was still the same and it was still standing up as strong at the same RPM. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6401563 Share on other sites More sharing options...
slippylotion Posted June 16, 2012 Share Posted June 16, 2012 (edited) So today I went to order some water line fittings for my tdo6sl2-20g from Kando via Ebay today to find out he has blocked me! When I bought the turbo he sent the wrong oil line in the kit and I tried for about a month to get a response from him after sending about 4 messages. So understandably the last message I sent was a little heated, to this I actually got a reply and the correct line sent out. I then apologised for the last message but he obviously went ahead and blocked me even though it was all due to his lack of customer support. Ive since had a look at his ebay feedback and appears that if any one allegedly isn't happy with the product or his service and leaves a neutral or negative feedback he just blocks them for ever! So I wonder how my warranty would go with him if I ever need it.... This is making me rethink if I even want to use this turbo now, considering selling it and going with a Precision 5558. End rant... Edited June 16, 2012 by slippylotion Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402226 Share on other sites More sharing options...
ARTZ Posted June 16, 2012 Share Posted June 16, 2012 whats wrong with your water lines? tried unplugging aac? see if it changes anything? So i unplugged the brown plug on the AAC and its running beautiful now.... Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402298 Share on other sites More sharing options...
Kane_R32 Posted June 16, 2012 Share Posted June 16, 2012 (edited) Hey guys, these 240kw and 260kw claims with the td0618g and 20g respectively, with what kind of supporting mods are we talking? Forged rebuild or basic bolt-ons (inj/pump/ecu)? Reason I asked as I have a RB20, TD0620G, Nismo 550, Walbro and NIStune. Produced 212kw @ 15psi. I'm almost certain this turbo inst efficient until 20+ psi right? Obviously next mod(s) are Z32 and Cam Gears, will this net the 260kw claim once tuned again? Engine is stock internals.. Edited June 16, 2012 by Kane_R32 Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402340 Share on other sites More sharing options...
Super Drager Posted June 16, 2012 Share Posted June 16, 2012 Hey guys, these 240kw and 260kw claims with the td0618g and 20g respectively, with what kind of supporting mods are we talking? Forged rebuild or basic bolt-ons (inj/pump/ecu)? Reason I asked as I have a RB20, TD0620G, Nismo 550, Walbro and NIStune. Produced 212kw @ 15psi. I'm almost certain this turbo inst efficient until 20+ psi right? Obviously next mod(s) are Z32 and Cam Gears, will this net the 260kw claim once tuned again? Engine is stock internals.. Are you still on standard injectors too? if so change them and put a Z32 afm on and it should make way more power when its retuned with more boost. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402350 Share on other sites More sharing options...
GTScotT Posted June 16, 2012 Share Posted June 16, 2012 the 240kw claim was based on TD05H not TD06, TD06 is a 20G job (you can order it in either but I recommend them that way) how is the TD06 mounted? stock manifold? internal gate? etc. Assume you have a bog stock R32 GTST, here is what you want (in a perfect world) to net a neat 260kw: Fuel pump 550cc injectors (or larger) Z32 AFM + Nistune (or other good ecu, being map sensor based will mean no need for Z32) New coilpacks or upgraded items 6boost manifold or similar quality item TD06SL2 20G 8cm 44mm external gate (or larger) 3" TBE without any restrictions 2.5" intercooler piping from turbo outlet to throttle body standard issue 600x300 intercooler or better 3" metal intake pipe minimum Adjustable cam gears start with a bog stock car and do those mods and you should have a neat 260kw. you can also use the stock manifold and hang the external gate off the rear housing, but that is yet to be done on an RB20 so i cannot vouch for its success rate. That is the exact setup I am running on my SR and am aiming for 270-280kw on 98ron. Motor will have cams though, as SR cams are not as nice as the RB ones from factory Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402360 Share on other sites More sharing options...
slippylotion Posted June 16, 2012 Share Posted June 16, 2012 (edited) Just on that 44mm ext gate, you can use a 38mm gate. Before I purchased my Tial 38mm I contacted Tial to see if I should use the 38 or 44 and they said for the TD06SL2-20G turbo the 38mm was ideal. Added bonuses with that is that the 38mm is cheaper and smaller so little bit easier to mount. Edited June 16, 2012 by slippylotion Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402367 Share on other sites More sharing options...
GTScotT Posted June 16, 2012 Share Posted June 16, 2012 This is making me rethink if I even want to use this turbo now, considering selling it and going with a Precision 5558. i really dont think the PT and a TD06 are intended for a similar application.... so going to one of those is like saying im thinking i want to go a completely different direction. put the TD06 on mate, it is what it is.. cant expect world class service from a person half the world away (postage is freaking expensive to send shit back anyway..) Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402371 Share on other sites More sharing options...
slippylotion Posted June 16, 2012 Share Posted June 16, 2012 (edited) i really dont think the PT and a TD06 are intended for a similar application.... so going to one of those is like saying im thinking i want to go a completely different direction. put the TD06 on mate, it is what it is.. cant expect world class service from a person half the world away (postage is freaking expensive to send shit back anyway..) Yeah your probably right, just a bit annoyed with the service, Cheap prices shouldn't mean sh!t service, I bet he's still making a reasonable margin. Its a pain I can't buy the fittings from him on ebay as to buy them in aeroflow or speed flow versions is about double the price and Im working to tight budget atm. Edited June 16, 2012 by slippylotion Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402378 Share on other sites More sharing options...
GTScotT Posted June 16, 2012 Share Posted June 16, 2012 have u got a mate that can help you? if not its pretty easy to make a second account and buy that way. is what i did at one stage for different reasons. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402383 Share on other sites More sharing options...
ARTZ Posted June 16, 2012 Share Posted June 16, 2012 start with a bog stock car and do those mods and you should have a neat 260kw. you can also use the stock manifold and hang the external gate off the rear housing, but that is yet to be done on an RB20 so i cannot vouch for its success rate. That is the exact setup I am running on my SR and am aiming for 270-280kw on 98ron. Motor will have cams though, as SR cams are not as nice as the RB ones from factory yeah Scotty made one up for another guy here, pretty much same setup as mine .td06 but with 40mm compgate.. I was there when it was tuned but cant remember, it pulled somewhere between 240-260 though and held boost well.. pretty sure that 212kw must be an IG model or a gate would of been listed...no doubt there inlies the problem Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402397 Share on other sites More sharing options...
Kane_R32 Posted June 16, 2012 Share Posted June 16, 2012 Compgate 40mm mounted onto stock manifold. From what I remember its a 10cm or 12cm (even possible on td06) as its lag city until 5500rpm.. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402550 Share on other sites More sharing options...
ARTZ Posted June 16, 2012 Share Posted June 16, 2012 no gate mounted on turbine housing and its an 8cm... Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402553 Share on other sites More sharing options...
ARTZ Posted June 16, 2012 Share Posted June 16, 2012 just had a look through the 20 thread but he hasnt posted.. on a side note just noticed Roy has cracked 300 on his rb20.. WTF...your meant to come here and brag about that shit Roy.. Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402561 Share on other sites More sharing options...
Kane_R32 Posted June 16, 2012 Share Posted June 16, 2012 should have a neat 260kw you didnt mention at what psi that would be achieved..? Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402566 Share on other sites More sharing options...
Kane_R32 Posted June 16, 2012 Share Posted June 16, 2012 no gate mounted on turbine housing and its an 8cm... if that was aimed at me, its originally an IT, with welded gate open. Then a External welded onto the stock manifold. TD06H-20G I'm told by previous owner Link to comment https://www.sau.com.au/forums/topic/347726-kando-dynamics-turbo/page/195/#findComment-6402575 Share on other sites More sharing options...
