I'll be on 4XKando power soon with my upcoming projects.
Yet to receive bad service.
Have also ordered a multitude of spares like lines, hoses, actuators, manifolds, dumps and other stuff from him and have zero to complain about.
for Ron: just remember that the 20G was always intended as a cut price option to a HKS GTRS, it was just lucky we also found they packed more power. You can reference this earlier in the thread.
I do like your plan though, low mount for the present and later T67 highmount when ur ready with minor adjustments to your gate off the housing and existing dump. :thumbsup:
Here is my result from Tuesday...
Nothing amazing, as there were a few things holding it back. One of the main things mentioned was that my exhaust (which was very quiet on the dyno) seems to be restricting flow too much. Tuner said the engine seemed to be having trouble breathing. So i'll probably have to look at getting rid of the cat, and/or changing the muffler. (it is 3" all the way through).
Exhaust cam timing wasn't adjusted this time due to the above ^^
This was also only on 18psi.
another t67?
Another T67
Some more info;
T67-25G
RB25 rebuilt with forged pistons, stronger bolts & bearings etc..)
Quickspool exhaust manifold (almost identical to 6boost)
Fake greddy plenum
Link G4 ECU
Big front mount
98 unleaded
18psi boost at the moment as I'm only using the built in 2.5bar link MAP, and a weak spring in the gate.
I will get around to starting a proper build thread for my car, eventually...
That's actually another decent result for the T67, between 4 and 4.5 for peak torque and 180kw so its definitely on the boil at the right time and you can tell power is still rising and could rev harder.
Retard the exhaust cam free up that exhaust, I rekon gain 300 rpm in spool and with a few more psi an easy 320kw.
make it dance!
After what I've read here about his shitty service I won't be contemplating buying his products. And I am in the market for a 250-300kwish bolt on for an RB25.
probably best that you don't buy kando turbo anyway as they are NOT a bolt on for Rb25.
look at the hypergear if you require a bolt on 300rwkw turbo for your 25 with a nice right angle mount straight off the housing for the ext gate (perfect for flow too :P)
i was being serious GtScott, cause if he doesn't get what he expects, you know he's coming right back here.
LOL Oh well. Cant help those who cannot be helped.
FYI to anyone wanting to buy products online or from the US:
I got my cams from Real Street Performance. From payment to delivered was 8 days (1 week and 1 day), inclusive of a weekend.
The cams were also cheaper than ANYWHERE else I had seen (only 380 USD for the pair, 220 USD for the springs and Ti retainers). Shipping was a good 90 bucks, but hell worth it, they came PROPERLY packaged and super fast.
I have bought my injectors, AFM and wastegate from Ebay USA, delivery to door takes roughly two weeks.. This bloody Eiji hasnt responded to my email sent yesterday and one today. Does he want to sell his Kando stuff or not.. :no:
Ebay Jase?
Its the same store as the on ebay, but I emailed them direct and they sent me a simple paypal invoice
http://realstreetperformance.com/store/
They do the PT stuff too, so you can look there for a super quick delivery and decent price 6262 when your time comes ;)
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
