Kando Dynamics Turbo
SimonR32
Is any one running a td05 16g on there rb20?
Looking at maybe getting one for my 20 for response I'm thinking it would come on around 3500 rpm mark?
Want to push around 220kw mark for a drift car !
Edited by colsil
Back in around 2006 my flatmate put an EVO3 TD05-16G onto his RB20DET on the stock manifold with an external wastegate plumbed up - made 20psi by around 3800rpm if I remember rightly, was awesome fun to drive though never got a final power figure for it unfortunately.
Here's the graph with your 17.5psi run Artz.
We should arrange a time to drive each other's cars (if you don't mind)... I struggled with the choice between T67 and TD06-20G for ages, so it would be good to drive a well set up version of each back to back.
Wow Except for that bit where you hit full boost , im still a bit on top.. until. 6k when im out..
Be a funny race , as long we get traction down the same you should power ahead when I change gear.
I would catchup when you change gear but I'd think you would stay well ahead..
I wasn't running out of legs on the straight at PI really, it was still pulling hard in 5th when I hit the braking zone..
We tried 20psi but it didn't make anymore power, intake temps starting going up. Might be different with a better intercooler. Trent said he was quite conservative with the timing though. Engine is also high on K's. Simon has shown the T67 will keep going with more boost, but this is the best we could safely get out of my setup. I'm not complaining though!
Yer I'm pretty keen on getting a kendo one maybe even go ex gate on STD manifold or just get a internal gate one just want a response turbo for drifting
if u do go internal gate, get a T25 based one (the SR20 type) as the T3 ones SUCK. You will then need to get a T3-T2 adapter and make a dump to suit.
that being said, i dont think it would end up that much more expensive to just go external gate TD05H 18G T3 8cm.
HOWEVER, if talking making that sort of power your probably BEST off just getting your stock turbo rebuilt by hypergear. it will work out cheaper and the chances are you will get better results as you can tell him exactly what you are after, no hidden surprises. you say i want full boost by X and this much power, he will tell you what he can make to meet your targets or how close you can get to your targets with which turbo.
An update to my pretty minor but annoying saga regarding a missing oil line and complete lack of communication from Eiji - after some negative feedback he finally got in contact and we have finally resolved things (and I removed the negative feedback). I now have the missing oil line and things are all good :)
I don't think so, his last message indicated he was keen to do business again, so I think all is good.
I did notice all those feedback messages on eBay though where he states, straightaway, any issue (even if he is apparently to blame), BLOCKED! No soup for you haha. That's why I was worried about things initially.
Oh well, all sorted now.
Did he block you afterwards Justinn?
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
