yeah, 226 pages later we have said plenty of times that the T3 internal gate kandos do not work. If you actually read the thread you will find results of ppl testing the iwg and that it sucked.
yes a 3071 is a good turbo, but just get a hypergear and save your money. Bolt with factory dump pattern.
an SS2 type B will be better than a 3071, based on specs.
this...
I have driven a 3071 Rb25 car (with a .86) and it was woeful to say the least and from what people say the .63 fails
admittedly i'm used to an HKS modified 3071 that is unbelevabley good.
IMHO go a smaller garret or ex gate
i just didn't feel the garrett 3071 was worth the money
I also think the cropped 3071 (HKS 2835) is an epic turbo for an RB. The delivery is brutal on an RB25, but I probably wouldnt go there on a 20. the bigger 60mm 3071 will be more responsive for the 20.
The Hyper Gear items are similar in spec to the garrett variants but Stao customizes the wheel sizes to be more application specific. The SS1PU and SS2 replace the 2871/GTRS and 3071 respectively, and is bolt on.
Mates, please advise: i have choice between Kando dynamics TD-06 20G and Hypergear 43 G. the cost of hypergear is bigger, but both of them are bolt on to the stock exhaust manifold.
could you tell me which turbo is better and why?
thanks
Hypergear is a bolton turbo, so it is far cheaper then Kando items counting installation costs. If you are comparing internal gate, stock manifold bolton performance its obvious that hypergear is a winner.Some of their latest billet turbos performed extremely well. They've released their billet version of TD06 SL2 20Gs that again appeared to be more responsive and punching out better no.s.
For a bolton turbo internally gated turbo for "Up to" 280rwkws I would definitly go for an hypergear item. Or if the decision is on a SL2 20G I would still go for a Hypergear's Billet 20G. for a 25G I probably go for a Kando item.
Put it this way, the kando internal won't work at all so you will need an external gate. By the time you pay 700 for a turbo and 400 for a gate, you are already nearing the cost of the HG. Then you still need to have your gate plumbed and dump pipe made which will cost over 500 easy.
you should make a responsive 260 on 98, 300 on E85.
Then you have the HG ss1pu. Complete bolt on, uses the factory dump pattern and all. no external gate, no dump pipes to be made. Just bolt on and make an intake pipe.
cost way less and still crack a responsive 250-270.
So had my rust bucket on the dyno the other night...
Old setup here: http://www.skylinesa...ost__p__6010134
Added ID1000s, billet comp wheel, poncams and re did all the pipe work in 2.5" stainless(was a mix of 2.25/2.5 before)
Tried more boost but it didn't really do much, perhaps a restriction somewhere (runs 2.5" cooler piping, 3" exhaust and stock throttle body) AFM was at max also.
Forgot to grab an overplayed map but if you put them side by side it looks pretty similar apart from the extra 30kw up top thanks to the cams(boost was almost the same). Most noticeable difference is how ridiculously smooth the thing cruises around with the ID1000's over the High-flows!
I love how these thing feel like your entering warp speed over 6000rpm lol, wants to keep rising even at redline.
Not sure what to make of the billet wheel though, perhaps the cams lost a little down low and the wheel brought it back up?? I think Simon will have to give one a shot so we get a genuine back to back.
Edited by battery
Thats on boost nice and early and making a healthy power figure battery :) I like your setup under the bonnet too. Neat and well presented.
Based on Stao's billet 20g results, I would say the billet 25g is also an improvement. I think all those parts come from the same supplier anyhow. So my logic is if they could improve the 20g im sure they also improved the 25g.
And if its warp speed at 6, you should rev it to 9 LOL!
Well you didn't exactly go backwards anywhere...
Hard to tell what made the gains, probably a mixture of both the cams, piping and billet front wheel.
Must be happy anyway, I'm guessing it still hauls ass!
No billet love for me, but I'm going to be selling my Green 32 very soon (if anyone is interested in buying PM me)
Edited by SimonR32
Yeh Trent seemed to think it would get to 380-390kw if we upped the rev limit, but im lazy and I'd prefer to not have to swap in another engine if the thing went bang..
LOL i can understand the logic, dont worry.
I wonder if theres a way you could shift the powerband to the left... I guess VCT would make that hard because you dont have as much control over the intake cam.
No! Don't do it Simon!
PM sent..
impressive result still , it knocks on the door of 200rwk at 3800rpm , why does it dip again for 100rpm?
I'd like to see an overlay. Might be wrong, but I couldn't see any significant differences at 4000, 5000, 6000, and 7000 rpm points although the shape of the curve between them may be slightly higher. I agree with Simon, it's obviously not gone backwards. But an overlay simply hightlights the advances.
The torque curve is showing a falling trend by 7000, and the bigger power number appears attributable more to a little kick in torque over the final 250rpm. Run under similar conditions with no other mechanical changes it would be hard to see the thing make the suggested power number simply through extra revs, but compromising your engine reliability would be a certainty at some point if you did.
All said, the result is certainly good, and dyno numbers can't be expected to convey the difference in feel as the engine runs through its speed and load ranges. Well done overall Battery, and I bet it does haul. Hope you intend tracking the car, not just dyno or 1/4 mile?
So pulled my TD06 of today..
Exhaust Side;
Exducer: 66mm
Inducer: 59mm
Running off this site; http://website.lineone.net/~jon_ed/Turbo_Table.htm.
Does it look like I have a TD06SH-20G (factory internally gated)
Bugger, that is the big bad boy rear turbine. So not the smaller turbine that most people run on a 2L or people here are using on their T67 etc.
From what I can see on the Kando website they only do a T25 8cm housing for that turbine. So you still need to do an adaptor for T25 to T3....then still running the biggest turbine you can run in the TD06 range.
May be best to give that turbo the flick to an RB25 owner who wants punchy 260-280rwkws that hangs in there nicely in the higher rpm
Bought myself a GTR, so I'm planning on going broke haha
Last weekend before I'm going to put it up for sale I've been playing at powercruise :)
Just to give people some idea how much abuse this consists of check this out
2 bar and 8900rpm :) Both were spikes but it still loves it
As far as reliability goes it's been nearly 2 years and the car has not had a single breakage since I put the RB25DET and Kinugawa turbo on.
Edited by SimonR32
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
