No tyres except bald A050s, and car is broken...ditto my Sierra which I am still fixing...so no:(. All my efforts are going into Nationals and by efforts I mean money. Still, the R32 is capable of a few 0-400mtr blasts but not much more :(
your 20 finally on its way? I don't believe lol
There are some not so great signs...it boiled all its coolant and burnt about 1L of oil the the other week when it split a heater hose under the inlet manifold and overheated in peak hour on a Friday night. Changed all the coolant lines/hoses but some strange things still happening which concern me. Its now just a matter of time I think
I sold my DE+T setup to a dude with this bright orange S14 and installed it for him as part of the deal. It left me running smooth but not liking boost too much due to rat shit battery terminals and holes in his cooler pipes. I told him to fix the battery and leaks then come back so I can set the timing as his crappy voltage meant I couldnt get the timing to lock. I also investigated why his heater wouldnt work, and found it to be that his core had been looped. I told him I assume this was due to the core leaking and recommended he doesnt reconnect it.
Brings it back a week later with the problems 'fixed' and its running like a total bag of shit. Heater has been reconnected and suddenly the water pump is pissing out fluid (assume it got debris from the reconnected heater core in it and rooted a seal). Not a drop of coolant in the radiator either. Cooler pipe has duct tape covering the holes and the afm has been pieced back together with gasket goo. I do my best to look for possible issues and problems but it still runs like ass. in the end I also felt like I was mostly being blamed -_-.
Point of the story, prior to me selling that motor it was only 45ks old and ran faultlessly. One little overheat and its turned into a pig. I hope you havent done too much damage Roy :( your little RB has been heroic over the years.
Got my Kando oil feed at my desk after ordering on Fri- absolutely brilliant service even though he didn't respond to my query. Thats what I ordered and looks like what it is in the pic:
http://www.ebay.com....984.m1497.l2649
But the plastic bag has TOYOTA 1JZGTE on it haha, is it the same part/fitting for the 1JZ/RB25..? Lol. It also has the code 2000-930-821 written on plastic bag sticker/tag.
Edited by rondofj
Kando says the part number for the RB25 line is 2000-930-821
so RB25 and 1JZ probably have the same oil feed thread pattern. No big deal.
But WOW what a way to get shut down LOL. ra ra ra he wont reply, ZING its at your door in 3 business days hahaha. Quality item for $41 delivered. Winning!
Yes man absolutely, no reply to my email, then next day I get a tracking no. on ebay, then couple of days later its at my desk in the morning before I am! lol
Edited by rondofj
That oil feed restrictor does look tiny though, bit skeptical if its good enough as its meant for an oil and water cooled garret T3/T4 core, whereas my PTE 5558 (still T3/T4 core) is only oil cooled.. turbo blowing up from lack of enough oil? hahaah :no:
Edited by rondofj
There are 2 ways to do the oil feed for that turbo.
1: A standard 2 bolt T3/T4 fitting like what Ron has bought
2: use a 1/8 NPT male to -4AN male adapter and then the same kit Ron bought but with the 2 bolt flange removed. The 90 degree fitting at the end of the line is -4AN.
The difference between options is $10 worth of alloy NPT adapter... HOWEVER I have found those NPT fittings to be quite soft and I wouldnt want shrapnel in Rons motor at the hands of an overzealous first timer.
So option 1 it was!
lol I doubt it ron. The innards of most braided oil lines is that small anyway mate.
Keep in mind that an oil feed restrictor for BB turbos is normally half a mm (0.5mm) or similar.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
