lol I doubt it ron. The innards of most braided oil lines is that small anyway mate.
Keep in mind that an oil feed restrictor for BB turbos is normally half a mm (0.5mm) or similar.
Thanks man, only half a mm??? Shhxxxxxxx! Thats small aye..
There are 2 ways to do the oil feed for that turbo.
1: A standard 2 bolt T3/T4 fitting like what Ron has bought
2: use a 1/8 NPT male to -4AN male adapter and then the same kit Ron bought but with the 2 bolt flange removed. The 90 degree fitting at the end of the line is -4AN.
The difference between options is $10 worth of alloy NPT adapter... HOWEVER I have found those NPT fittings to be quite soft and I wouldnt want shrapnel in Rons motor at the hands of an overzealous first timer.
So option 1 it was!
lol, cool, i'll get one..im just as bad as ron and you for turbo decisions..lol, but i just bought a nz side mount and are going to get the same 5558 and run gate of ex housing, have 260 ponnies and inject 500cc of water/ meth and see how it goes..i just got my auto trans built, its rated to 350rwkw, and i can only get a 3000rpm converter and still retain lock up...so downsizing from 3540..just need to sell it now..
cheers
darren
Edited by jet_r31
LOL nice, I do see that you traul the same threads we do haha. Glad to see more PT results are going to filter through now tho. I was so tempted to jump on one too, but cost and simplicity won in the end (read GF won in the end). Im confident the SS1PU will get me what I want for now and my motor will be built for up to 600whp, so I can always go bigger if funds permit later down the track.
As a quick update to my build I do have my SS1PU at home already, and just finished my buy on all motor parts. Am running CP pistons, manley rods, ACL race bearings, Tomei Poncams, BC cam gears/valve springs/titanium retainers, ARP head studs and all genuine nissan chains/pumps/guides and bolts.
Once the final bits and pieces arrive in the mail over the next 2 weeks I'll be playing lego and will probably pop up some photos somewhere on here. Fingers crossed for a very responsive 250kw.
With that sort of internal parts you could go 250rwkw X 2 or 3 and still be grinning ear to ear with the same confidence...
Semi agree for 2x but not 3 lol.
The CP's are top quality pistons so I'm not worried there at all. The Manley rods are rated as good for 175hp each, which is 700 total. ACL race bearings are used in much higher HP application and the stock crank again has been used in much higher HP cars also.
I havent studded the crank tunnel and the block is not going to be grout filled so I will say the safe limit of this motor will be roughly 400kw. If 500kw was available I would push it there but I would expect it to lunch a rod at the first sign of WOT detonation.
If I was to redo it in a couple of years (for the 400kw mark) I would lift the head again and do a 3 angle valve grind with stronger valves, opening up the ports a touch while im at it. I havent touched the ports this time around and valves have been left 180xxxKM proven.
Did you get a oil drain aswell Ron, looks like they use the 50.8 spacing T3 one..if i had a bet i would have lost....
i thought they would be GT30 line/drain based for sure
Can't believe you can buy this shit so cheap and don't even have to make it..wasn't long ago you had to buy
a piece of pipe or get a offcut and a flange and make a drain for f**ks sake..to buy a nice bit of braided rubber for a drain costs more than the kit ffs...lol
cheers
darren
Edited by jet_r31
LOL yeaaappp. How good is it?
FYI Kando sell the same item for a T3/T4 oil drain as they do for an RB stock turbo. My bet is that the stock oil drain, with the possibility of a slight elongate on the holes, will bolt straight on.
I hope it (stock oil drain) bolts on as Im relying on your advice Jase! Lol. Just opened and tried the kit on the turbo-yes it bolts on of course, top quality item man, the oil line hole size is bigger than the hole in the oil restrictor flange which is tiny, the oil hole in the turbo is even bigger but is threaded/ why?? I think I will have the oil flange/ restrictor hole drilled out to the oil line hole size for peace of mind..:S anyone done this?
Edited by rondofj
lol no dont drill out the hole dude.. its fine as manufactured.
The oil line can be done in 2 ways on the PT, either with the threaded hole or the 2 bolt flange. Seeing as the 2 bolt flange came in one easy kit we went with that for yours. Instead of buying multiple components to do the same job.
This thread is turning gay... Thanks ron!
On the way back from Powercruise I did a few 4th gear pulls and was gettting 15psi (1bar) by 3200rpm so it's 300rpm better with the Tomei Poncams and Vipec combo than when I had Nistune/Z32 and stock cams
Got mine tuned today. 380rwhp @ 17psi. We had problems all over the place getting it running, once those were sorted then had issues with trying to tune it with the ECU not playing the game with the TPS. The guys did an awesome job in the end and we called it a day as just run out of time.
So thats the T67 with antisurge, NZ manifold, Tial 44mm MVR, Stock inlet manifold/TB and 98 oct.
Will post a sheet when i get it, was in a rush to get home so forgot it. Haven't driven it yet, just got home as i live 3hrs from the tuners and she's still on the trailer.
Should be able to tell if you and your mate with the anti surge 76 patrol go wizzing by then ;) can clearly hear him go past every evening.
And if you hear one whistle and then a really obnoxiously loud SR20 he's driving his Silvia then and im in mine.
lol so the antisurge worked ok then msports? thats good feedback to have
Seemed to have yeah, it is BS loud when your standing right next to it though on the dyno. I'll take it for a drive this arvo and gauge the response.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
