Yeah you can use the stock manifold on the smaller 20g, but he's right about the rest of it and the question was specifically asking for a 6 bolt option.
if you want a 6 bolt internal gate you will have to look at hypergear. even the 6 bolt 3076s have proven to suck compared to the full custom route.
so long story short if you want a good low hassle bolt on turbo you need to look at a hypergear.
anyone wanting something different or more custom for whatever reason can look into all the other options.
Has anyone used one of the Kinagawa actuators before? Specifically this one:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290784794658&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_1998wt_1414
And if so:
1) Are they any good?
2) I assume this would fit a GTX3071R (A/R .60 front cover)?
3) Is the top of the actuator rotatable so I can reposition the boost input to any direction I like?
Cheers! :cheers:
Justin
I have one of those at home but am yet to use it. I will update that in a few weeks if you can wait.
Its actually a 2 port actuator, just ask Eiji for a second nipple as the thread is there.
You can undo the top and rotate it, yes.
It's a good quality item from what I can see. No issues from me.
Hey guys, finally got my TD05-18G mounted. Just curious, both water inlet/outlets have an "upper" and "lower" ports for the banjo fittings. Are you able to mix and match which ones you bolt into? I.e use the upper for the inlet side of the water lines, and lower for the outlet? I didn't even think of this before bolting it all up.
P.S TD05-18G Ext Gate 8cm 100% won't bolt onto the stock manifold without atleast a 10cm spacer, and longer studs.
did u mount urs to the stock manifold?how long were the studs u used?
Yeah stock manifold, I wound out my studs 2-3 threads to give me enough thread for the nuts (8-9mm in thickness) to bolt down.
If I run into dramas later on then I will try replace them with ones about 10-15mm longer then standard/
u cannot use the water ports for in and out on the one side of the block.
That CHRA is a copy of an MHI core which has 4 water ports.
On some models they come from factory using 2 ports from the same side.
If Mitsubishi fit em up like that from stock, I doubt they would agree that you cannot do it.
Does the return on the top only apply if both are on the one side?
No, the return needs to be at the top if possible, otherwise the turbo may fill with steam or just hold air in the pocket. I guess it depends on the setup though and how hard it's driven.
Just think of what would happen at the track, the turbo is red hot and will be for a while as you pull back in. The water is barely flowing at idle and if you turn the engine off there is no flow. In this case the water will turn to steam and it needs to go somewhere. It needs to get to the radiator cap to be purged from the system.
The steam and hot water can create water flow if done right using convection to cool the turbo better.
I forget the name of it...but there is a word to describe the principle of water circulation after the engine is shut down. Hot water rises pulling cooler water up through the core so there is actually flow through the turbo after shutting down
i believe its convection
I've fitted my T67 up yesterday and i'm having trouble with the vbands being shithouse and not tightening enough. Mainly the one to hold the CHRA in, it doesnt do up enough to stop the core from moving, I can see this being a pain and having to keep moving it back.
Has anyone else got this problem???
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
