so consider my options.. i want a nice meaty 400 rwkw, used for drift, dont want to have to rev the crap out of the rb30. so what should i choose
ando TD06SH25G, Kando 267 25G or a Precision 6262
Read the results in each thread and make a decision. From what I have been reading in the precision thread those guys are getting some amazing numbers.
JEZ managed 400rwkw on his 26
From what he said it could have kept hauling except he only has a stock bottom end
Mook...pity you dont have an egt gauge..if it's getting hot its most probably a 8cm...kind of looks different to mine which tapers out more towards the flange but it is very hard to tell from the pics..the results definitely seem to point at a small housing ..
A 10cm housing from kando is probably cheaper than an egt gauge anyway though..id say buy one for 150$ and swap it if it doesn't work your only down 150$ at worst but you can still sell it off again.. :D
Good point!
Jez stopped at 400 to preserve the motor. To my knowledge the tune is not as aggressive as it could be, for safety factors.
On his dyno it didnt plot much worse than his -7s.
Very epic.
Very epic.
I may have purchased poncams to beat a mate on my dyno again,
Will post up after cams and more tuning :)
ARTZ which direction should I take a photo from for the best view to see the differences?
I'll take some more and post them up.
Hard to tell but looks similar size to mine, i made 380rwhp @ 17psi on 98 with the anti surge front end, although mine is a lot laggier then your's.
Msports.. is you car running a 25?? if it is that would explain the laginess, but the hp figure is very close to mine, maybe it is as much as its gonna make on pump fuel.
This is pretty much what mine looks like, i tried to take a photo where you can see the flange, but they all ended up dark and crappy.
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-Mitsubishi-TD06SL2-20G-T67-25G-10cm-T3-Flange-/281016579887?pt=AU_Car_Parts_Accessories&hash=item416de4b72f#ht_2085wt_1186.
I the picture is correct to the description i'd be pretty sure i have a 10cm, now the problem is i cant find a 12cm housing with the t3 flange and a v-band outlet to fit into my setup.
Didnt you say yours is a 25/26? What would make that more responsive?
They definitely should push 300kw on pump. It has been discussed before and STATUS has confirmed 330 is do able.
It can come down to the setup itself and the condition of the motor also. Sloppy valve springs or rings and it could push less power than others.. sometimes you would never know other than the down results.
I'd doubt the 100cc extra from running a 26 crank would make that much of a difference?
We run out of time to tune mine more due other issues taking up time, so i think we should get more? Unless the antisurge is really holding them back?
Theres less than 100cc between the two and it would make SFA difference.
To my knowledge the 26 has a lower static CR which would make it spool slower if anything.
Obviously no offence to the owner - his results are great, just stating the obvious.
also Msports used hyperdrive's dyno. which doesn't correspond to any thing I ahve seen on the east coast. For example my car on hyperdrives with a rb30 made way less peak power then stao's rb25 with MY turbo by miles. the only thing that could be compared was the boost plot and the curve at how it made power.
How ever during the time your car had missfiring and AFM issues plus other problems, the turbo was used as a stocker bolton with stock exhaust manifold internally gated at 16psi, 270rwkws at the time by hyperdrive was more then reasonable.
The 58T 3576 in.82 stopped making power at 335rwkws on pump98 with 25psi of boost on my Rb25det, I don't think your car would be far off to it with every thing in working order at similar boost level.
The SL2-25G has a much smaller turbine in comparison so it will have better power band downlow, how ever will definitly not make better power used on your old setup.
Stao, I hope you didn't take offence to my comments as it was never intended to. I was simply saying that his dyno print was low but so was mine.
But I will say this, I spent alot of money trying to get that setup to work BETTER (don't get me wrong it wasn't bad by any means) and the best it ever did was around 370 (timing fixed, AFM fixed, poncam's, side pipe, wastegate actuator's etc, EGT sensors & a AFR setup) I just think it was too small for the 3L and choked it with any more than about 18psi rammed in it.
For me the TD06SH-25G is a better match for my current setup. As a test we are fitting my old 3576 to a mates Rb20 silvia so it will be very interesting to see how it reacts to a smaller cap motor.
regards
Chris
Finally here is a couple of pics of my turbo housing, i think it is a 10cm but it is just too small for my 25/26 with cams. We ended up getting 275RWKW out of it at 20psi on BP ultimate. It spools up to full song at 3500 and starts to drop off around 6000. It is very good to drive but we were pretty disappointed at the power output.
Simon, i suggest waiting to see how i go before getting the T67.
something else is definitely wrong, as that is similar power to what i made on a 25 neo with a td06sl2-20g 10cm.
the 10cm housing is tiny anyway as i raised this question before thinking the kando 10cm are so much smaller than the trust 10cm housings.
compared it with Jez's drift car and it was the exact same.
IIRC mookas engine is 9:1 comp and with the cams it is pushing a decent amount of air out of it. my money is on the exhaust housing being too small, engine is sweet
red line on this graph is EXACTLY the same engine running the old 35/40,
mooka dyno sheet comparison.pdf
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
