Thanks bling.
Its not that the T67 is bad, it just seems that it is choking the engine. Super early spool and a drop off at high revs.
I sent a message to Kando too. He says he doesn't have a 12cm for the T67. So it looks like I'm sticking with what I've got for a while anyway, at least till have money for another turbo at some point.
do the anti surge front covers not perform well?i have a kando td06 sl2 20g with a 8cm rear that i am putting in my r33 at the moment.i was looking for a 10cm rear and contacted kando and they said i would have to buy it seperate.but i got the turbo and tial 44mm mvr wastegate brand new for dirt cheap so i couldnt let it go.just hoping the anti surge cover wont cause any problems
You can get the housings separate, exhaust side is about 150 and intake is less.
Mook it might be worth you just getting 2 housings and giving it a go. Assuming antisurge might be an issue and it might be an 8cm.
You can use boost pressure to help hold the wastegate shut. Definitely worthwhile.
I finally got my Kinagawa actuator, I asked for the extra nipple but didn't get one! I might be able to find something with the right thread to suit though.
The actuator itself looks very good.
We have the car on track today and my exhaust temps are through the roof. Melting the tar on the floor inside and the carpet and the mat on the carpet. So guessing the housing is way too small.
Andy, Do you have any pics of your 10cm housing for me to compare to mine please
This can be from the tune also
Thanks for the pics guys, my housing looks pretty dam close to the ones in the pics, so i think it may be a 10cm
What in the tune can cause so much heat??? I dont mean to sound like a smart ass there, i honestly dont know
ARTZ, i dont think so, i dialed the cams in when i assembled the engine and they are within 1/2 degree of the factory settings.
My car blows fireballs the size of a car so i dont think its running lean, :yes:
I backed the boost off to around 16psi from 22 to control the heat, it was stupid hot at winton this weekend. It did make a difference, as it should.
Edited by MookRG
No cat, does have a straight through muffler and a res though,
The AFR's were a little rich on the dyno, not heaps just a little to be safe, from memory they were around low 12's high 11's i think. I'm pretty tired from the weekend, i could be wrong i will check later today gonna go see my tuner.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
