So a 3076R 0.63 which is smaller is EVERY way can be ok on a 30DET but this is too small...
i think you are missing the point here! you are saying that the turbo is ramping too early and has no legs up top? im saying too small as in maybe they sent you thr wrong turbo!
a t67 should but upwards of 300+wkw with no issues what so ever!
Hey guys,
In a bit of a pickle, I've got a TD06-20G 12cm on my RB25 and it's a lot laggier than I expected. Although it wasn't tuned on what boost I wanted (20psi), it's only running 13.
I'm guessing that the turbo isn't in it's sweet spot and is taking it's time doing anything. I've been searching for weeks about info on the 12cm but I can't find shit (yes I have searched this thread many times!).
Has anyone run or tuned such a beast on a 25?
It made around 235kw which is decent power for the boost run I guess but yeah wasn't expecting it to have full boost around 5500rpm, any ideas?
Edited by Run-It-Hard
Hey guys,
12cm rear will add to the lag
chuck a few more pounds into it and see how it perfoms but will def be sluggish under 4k
It's out of the boat yard finally :P
Will more boost change the power curve, i.e turbo start working it's magic earlier? I was looking at two graphs somewhere in this monstrous thread and it seemed this way (same car, two sheets at diff boost levels). But yeah I'm noob with this stuff.
Hmm I wonder if that 10cm would fit.
Is it a TD06S or TD06SL2? That will change what housing you need to buy.
Either way a 20G on a RB25 with whatever rear housing should be running a 10cm.
Your 12cm is just making it doughier without benefit. Easily fixed though as mentioned.
Also, is it a T3 or genuine trust 3 bolt?
It's a TD06S and it is a T3.
Spewing eh! Ahwell I got it cheap ($600 via Ebay special). Atleast it's fixable, just a pain in the arse lol.
I wonder if Raz' 10cm rear would fit my turbo, hmmmm.
Cheers for all the help guys :)
Unfortunately it wont.
The SL2 is 61mm but the S is 65mm. Kando doesnt even sell housings for the S no more.. You are better off selling it as is to someone with a bigger motor and swapping it out for a Kando item. Im guessing its also internal gate with that abortion of a 3 bolt discharge?
Unrucky.
Alternatively, you can send it to Hypergear who will be able to machine up one of his 5 bolt Type B rear housings to make it dance.
Hey guys,
i saw trent talking about running a tdo6 (of some description) with 12cm combo on a neo...my guess is it will come on a little later but make hard power all the way to 8000rp+ and then some ...5500 does seem a little ridiculous though..vct working?
So pump it full of boost and rev it hard and hopefully you should see some good results..good for hard sliding anyway...if its a streeter/racer drop it back to 10cm...
Here you go Jez
As far as I know, it's a untouched RB25. Full boost is actually 5750rpm lol, as you can see it's a slug to drive off boost too.
I've spoken to Eiji and they do make a 10cm rear for my turbo so I'll probably get that sometime next year.
Really wasn't expecting it to be THIS laggy, live and learn I suppose.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
