I need help turbo experts.
In a Kando Dynamics what would turbo would be comparable with a T04Z 1.06ish A/R? I'm terrible with this stuff so please be kind.
Cheers :)
Cheers :)
T04/66 P-trim..i reckon they even did one with a 1.00, last time i checked
they sell them as T04S/T04R with 84mm compressor wheel
Edited by jet_r31
Yep, the one that Artz linked is what I came up with as well.
I think we're onto a winner! :D
A Freddy plenum isn't really going to help much either..the stock one can handle anything a td06 20g can throw at it....probably make better torque too..also if you get the right ecu you won't need a boost controller ;)
I forgot to add that i am running a apexi power FC with hand controller, i know the freddy plenum wasnt the smartest move but i did it to tidy up the engine bay until a fab up my own one...eventually.
So in your opinions would the anti surge be more beneficial as opposed to the non anti surge TD06 20G?
well if you already have a freddy its fine, i just thought to save some coin if you were planning a build.. . :thumbsup:
seems non anti surge is the go, mine works fine without it anyway...have you considered a T67?? seems your all set up for it...
If you lay the charts over each other there is nothing in it..tdo6 has a little more torque downlow but if you are already top mounting may as well go t67 its a killer...see hypergear he has a new billet job too should be even better..
Hmm well this just made things a whole lot more difficult to decide hah, is there dyno graphs on this topic for both the turbos'?
i wouldnt mind seeing them to compare, of course the graphs would have to be based on RB25DET, with relatively similar mods. i have been looking but cant really seem to find them.
Yeh I'd be taking a hypergear option over a kando if I was looking today... Have a look at the SS2 ex gate results, it seems to make the power earlier on then fall off around 6500 where as the T67 dosen't seem to reach full potential until 7500 and beyond.. so realistically for a car with a stock rev limit I think the hypergear is the smarter option??
Kando is cheaper I think? but you get much better service before and after sale with the hypergear.
I emailed Kando about a non anti surge housing, suprised i got an email back after i was told i was blocked after leaving neautral feedback. $175 delivered, in stock now, i'll order one and do a comparrison.
I just bought a billet t67 of Stao with his own comp wheels profile. Must sell my previous setup to fund the new one lol. some one buy it
http://www.skylinesaustralia.com/forums/topic/416349-td06-20g-l2-complete-turbo-setup-for-rb25-290kw-setup/
anyone used the billet comp wheeled t67 yet im purchasing a new core is it worth the extra 200 ???
Yeh before and after graphs are in here somewhere... Hard to say if it did anything cause I put in poncams at the same time, boost didn't come on any earlier so I'd say pass. Maybe you could get it at half price if you ask him to fit it before sending.
It seems that the benefit of billet compressor design is in improved efficiency at higher PR, not in dramatically reduced boost response times. Still be interesting to try them back to back if only to see whether response and power delivery is any more/less progressive.
I'd say unless you are planning on running 20+psi stick with the std comp wheel. For my money I would be asking about the thrust bearing - seem to recall spotting a "race" upgrade to 360 degree version in the Kamak catalogue.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
