Looking at geting a Kando turbo for my HR31 Drift car.
Eng rb20 R32 motor
Aside from the usual exhaust, Fmic, injectors head gasket and studs nistune ect
it has Kelford 258 cams
Was previously running a VG 30 turbo 45v4 front 71 V rear and was happy with it made 209 KW at 15 lb with no drop off in boost in the top end
After 3 years of abuse it finaly lost the rear wheel
the two turbos I had in mind were either TD05H - 18G or TDO5H- 20G
The plan is to buy an external gated version, and run either a 40 or 45 mm Turbo smart external gate out of the turbine housing as I have seen the internally gated turbos either be lazy or be unable to controll boost. The turbo will be on the Factory manafold.
Im after the turbo that will be the most responive and make 240 ish kw on 98 pump fuel on a Mainline dyno. Am i in the ball park with either of these turbos?
on the site there is a billet wheel option on the 18G is this any better than the std 18G?
For the effort you are much better off sending your blown vg30 item to hypergear. 900 later and it will bolt straight back on, just get it retuned and party on.
by the time you set up your gate etc you will have put a hole in more than double the money. The differences in performance is anyone's guess but most likely not worth it.
I am yet to see any hi-flow turbos work really well on an RB20. Perhaps the Hypergears are different?!?! I have not really seen any results in his thread or on forums.
I would not go with a TD05H 20G myself. I run the TD06-20G and they are good for about 260-270 on a std RB20 on 98-100 RON fuel. When I switched to E85 I was able to make 310rwkws with the 20G.
I also have a spare TD05H-18G Kando that I had planned to back to back against the 20G. My expectation was it would only lose 15-20rwkws but have far nicer transient response losing some of the "big turbo" feel the 20G gave the RB20.
I subsequently spent too much money on holidays and booz and have not been able to trial the other turbos on my RB20 so if you are keen for a Kando TD05H-18G then I have one you can buy without the rear housing. In my mind I always thought they would be an almost 2530 like turbo just with the extra 15-20rwkws that 2530 couldnt quite give
Heres the graph for the older spec SS1 turbo:
http://www.digi-hardware.com/images/dynosheets/atr43/atr43ss1/r32/rb20det225rwkw.jpg
He could easily get the VG30 turbo rebuilt into the SS1PU specs (birds also got this core put into stock housings). Mine stacks on really well between 4 and 7 on my SR even without VCT, and so Im confident it will be much of a muchness on an RB20.
I know my car has a manifold but it also has a clunky TD06-20G and comparing my thing at 4,000rpm, 5,000rpm & 6,000rpm it doesnt look that great a turbo.
RPM______TD06__Hypergear
4,000______ 135____125
5,000______228____205
6,000______245____225
My numbers are off a Mainline Dyno that people claim read low. I know it read about 15rwkws lower then where my car got tuned. I argue that std manifolds are sh1t even at this power level but everyone in this thread tells me I am wrong. I still belive it but spells out you may as well spend the extra 1K on the manifold and have a 260rwkws setup with better reponse then a hi-flow on the std manifold
Need to consider thats the older outdated SS1, which is essentially just a 2871.
The newer SS1PU is better.
On the 45 degree day my car went as follows:
RPM______TD06__SR SS1PU
4,000______ 135____140
6,000______245____228
Bare in mind my car made 227@5000 on the base map, on a 30 degree day with 15psi of boost (whilst running in the motor). My car has also been tuned as a brand spanking new motor that will go straight on the track, and was tuned in 45 degree heat. So there is a lot more left in it.
On my current tune your car is ahead. When the time comes for a proper full power tune I doubt I will go backwards from the base maps 227@5k. Mine is a stock position turbo, running the stock manifold and an internal gate. It costed sub 1K and bolted straight on where a stock turbo would have otherwise fit.
Food for thought. I still dont think any turbo works well on an RB20 with std manifold. SR20 only has to worry about pumping pulses from 4 cylinders not 6 so not as big a compromise with 500cc of gases fighting down a 4cyl manifold vs 333cc down a 6cyl manifold with regards to the energy that is left to spin a turbine
Also people say SR20s pins turbos harder than RB20s so ?!?!!? And your dyno is DD so if use my DD numbers (bigassumption that two different dynos in different states are similar) then it looks more like below. And that is with a track tune that iteself is down ~15rwkws of what it made with more ignition on what you can run with a street tune without having to worry about 100deg water temps and 130 oil temps. Same boost though
4,000______ 140____140
5,000______235____205
6,000______255____228
LOL, its interesting whilst hard to compare merits of turbos from different cars tuned by different people on different dynos. Going on what I have seen on RB20s, hi-flows dont generally give you a good compromise of grunt and response. Often its the response of bigger turbos with marginal improvements in grunt.
Silly RB20s are sensitive things when you try to put turbos on std manifolds. If Hypergear can build you a ball bearing GT0SS T3 equiv then thats what I would be doing for the power level you are after. Small turbo and spin the thing hard
Neg, made 234. The 228 was just @ 6000 revs.
As noted it made 227 @ 5000 revs the day before, with 5psi less boost and on the run in tune.That was on the 17/01/13 with a max of 29, the very next day the weather was 40+ all day long. Workshop temps were over 50 said the tuner.
http://www.elderswea...t=site&lc=66062
Roy while I do appreciate the difference in motor, I still am not sure the additional in effort and cost is warranted. The core flowed into stock housings will bolt back on and go for the retune, not the 3k needed for the kando/manifold/plumbing.
My dyno sheet to follow.
I have a TRUST TD05H-18G going on the laurel as we speak, old HKS 2535 literally exploded... massive roller bearing failure lol Should be a good thing.
I am waiting for him to clarify if he means low mount or stock manifold.
Nobody else on the forum has that result, squillions have tried.
Low mount spaghetti manifold :P std manifold is junk over 300-330 as it works things waaay to hard.
any recommendations on low mount manifolds? I'm after a low mounted solution but not many non stainless manifolds available that are of good craftsmenship
But comapring a freshly built 4cyl 2L with a used std RB20 is probably not going to shed much light on how it will go. Show me the difference between the SS1 and SS1PU and that may shed more light
I do all my own fab so its only material cost, and I get my tuning done at work. so it wont cost me much in fitting ect, also I found the VG turbo has a massive crack in the rear housing around the waste gate so the housing is stuffed.
should have CATs interesting 5.7 litre twin kando project on the dyno in about 3 weeks so i will post results here first... as i know 5.7 stroker kits are all the rage in skylines nowadays :P
    • Hey y'all, I have a completely stock 1991 R32 GTR, yesterday I took my car out and went for about a thirty minute drive. It was fine on the way there but when returning home I think the car might have gone into a limp mode. I was cruising in 5th gear around 130km/h, the hicas light came on and there was a significant loss of power. About a minute later I hear a thump, the car starts driving normal again and is fine the rest of the drive back. This is the second time its happened, same as now it was fine on the trip there. On the way back it had the hicas light on but that time I would feel the power going in and out before hearing the same thump and it being fine.  I have no idea idea what causing this, but if anyone has any ideas it would be great as a start chasing the cause of this. Also I can provide more details if needed. Thank you
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
    • Today in Skyline arts and crafts!! I’ve made some progress.    had to put extra notes in there so I don’t stuff it up 😂
    • This sounds like me. And then why I leave shit that I had previously hobbled together broken. Lately I've changed strategies to "If I don't want to justify the money on decent stuff, I'm not going to justify hobbling it together". I'm still for DIY, but DIY it properly is more my thing. However, I am terrible on not setting up backups still... Which reminds me, I need to go backup some of my work VM machines... Oh, it's also why I've become a lover of building things into Docker Containers... Then I just need a machine that can run docker, and bam, that specific system is up and running, on the specific versions of everything I need for it to run (In the event a change in required software version breaks something else). Also, these days, my steep learning curves are spent with work related stuff, and on very varied projects, that my want to do other random projects like build a dashboard for my own car has dwindled away to "I just want the car running", which is my current PITA, as I'm getting the Landcruiser usable again, and it has just been non-stop the past 6 to 8 weeks of buying parts, and working on it. Oh, and tools that are meant to be fit for purpose... And they break, because 25 year old 4WD decides it's stronger... But by the time I have it ready to roll back out the drive way, nearly all the stuff in it will have been touched and serviced, so the damn thing better give me NO FREAKING ISSUES, for at least the next 50,000KMs! Just redone whole front of the motor, and resealed the up top stuff, replaced a bunch of things getting perished, new timing belt done, water pump, lower timing cover (Toyota diesel engine runs timing GEARS for the bottom half the motor, and a timing belt from halfway up to the top), new harmonic balancer, fix up the alternator, new thermostat, full swivel hub rebuild, new bearings and seals front and back, steering box rebuild, new battery, and today, it turns out a rear shock has let go, so four new shocks are about to go on order, and that will leave me with after the next run of work, to see if I need to order just a brake caliper re-seal, or if I'll need new pistons in them too. Oh, and I'll finish welding in the new floor sheet metal shortly too. Presently I just want it finished already... But once all the above is done, I still need to fully service diffs, gearbox, transfer, and motor. Then flush and bleed the clutch, and flush and bleed the brakes. But enough about our waffle, back to Duncan's heat problems... I think for Duncan he just gets a thermoswitch, and a manual switch to run some water misters. Thermo so it's only on above certain temps, and the manual switch so it can be turned off even if it is above certain temperatures. IE, switch on for "I'm now on track", then it doesn't need any "smart" computers that might try and do things wrong. And switch the thing off completely on the cool down lap, so when he stops in pits, there's not even a possibility of it dripping any water out to get him in trouble.
