^^^ oooh but the sound alone is worth 1000 dollars :) that car got the second largest gathering out the front..... 1st place was a supercharged M5 so dont feel too bad :P
haha I won't be surprised if i change my mind in a few months and come knocking on your door lol
the runs are way less that 15seconds, the red one from memory was with a mega retarded exhaust wheel, i was trying a few things and it just so happens the valve springs did not play up as much on that run. i only included it as a comparo to say it still has alot more in it.
On average we use a relatively short run rate 9-12 seconds.
Final position of the exhaust cam wheel was so close to zero it is irrelevant :P
Interesting... My exhaust wheel was set at -4 so we just left it there and didn't fiddle with it, looks like you picked up some mid range with it closer to zero. Might have to try if I ever bother going back to the dyno :)
Have you considered cams for your setup simon?
I've considered it, but since I've pretty much maxed the turbo I doubt it would make much difference, maybe the same power on less boost.
Realistically I've got more than enough power as it is haha
As for e85 vs pump, ... when i was talking to trent ... he said there could be up to a 50kw gain from E85 over bp98, ... atm im around 255-260rwkw on bp98.
Yes there is no doubt that E85 offers significant benefits, which was the basis of my question. Perhaps best answered by Trent - for a reasonably well sorted T67 25G (eg OMY31T or battery) running BP98 - what general benchmark have you seen or would you expect? E85 is not widely available in Qld so it's of interest.
Im a big fan of bang for buck setups ... with that said i don't think its fair to compare this setup with an IW garret or high flow low mount purely because of the legalities involved..
Understand your point of view on this one. I'm a little different, just looking at it from spending X dollars, and getting Y result. Redirecting dollars saved on turbocharger into a proper fabricated manifold and external gate is not silly, and something worth considering.
Trent told me he likes to do a base tune with 98 first my car made 300kw on bp98, not sure on the boost level that was used....
Considering how good the results are (~300kw on 98 and ~340kw on e85) and spool is around the 3500-4000rpm mark, what is the next size down turbo?
As if it makes say ~280kw and is spooled completely by low 3k to 3500, sounds like it might be a GT3071 killer for response. Or is it possible to just get a smaller hot side with similar results?
Edited by Rolls
exactly I'd still really like to see a result with the TD06SL2-20g 10cm
Youtube shows 1JZs doing 400ps (300ish rwkw) and standing up strong from 3500.
That is the said turbo ala Rolls.
I cannot wait to buy one for my JZ, but am SOOOOOO tempted to go T67. I was actually planning to create a poll thread for myself (I am willing to click but it now tonight) but maybe we can just discuss it in here?
Can I get a show of +1 for 20G or T67?
EDIT: I should also mention I am MR SUPER RESPONSE incarnate, however am also needing to school some people who may only be game to drag.
Haha its a hard one I think the T67 is perfectly usable on the street but i'd still like to see results for the SL2
But really If its 100% street and you want 260KW with brutal response wouldn't something more legal like a GTRS be a better option. The external gate makes you a massive target you really have to pick your spots..
Edited by battery
What is the next size down from the TD06SL2-20g 10cm which would make ~260-270kw? Sounds like that would come on just after 3k which would be amazing for a street car.
If you can find a 10cm housing for a TD05-18G that'll be the next step down from a 06-20G.
Edited by D_Stirls
Im running a 1JZ and cost is a major factor for me, so GTRS is not so much of an option. Believe me I savor internal gate like nothing else but my options are not to my liking.
On the GTRS note, I could just get its T2 footprint counterpart but miss out on the port shroud option. Plus I believe the 20G is more power with better response than 3071.
As for whats under SL2 20G, that could be a great number of things.. That could be a TD06-20G (minor downsize in ex wheel flow), or a TD06 based turbo with an 18G compressor (similar in physical size yet smaller in trim) or you could even look to a TD05H 18G or 16G.. TD05H-16G is whats factory on an evo and has been known to do 230kw at all 4 (2L 4cyl AWD) all day long.
The MHI range of turbos delivers.
what's the difference with the 20g SL2 ?
Basically I'm curious what will better my GCG highflowed rb20 turbo, it has ~GT28 ish spec internals and makes 240rwkw currently, awesome response but dives over too early, would be nice to say increase the response from 3000 rpm to 3500rpm max and hold the power to 7.5k instead of diving over at 6.5k
TD06S = Inducer 65mm; Exducer 55.3mm, Blades 12
TD06SH = Inducer 67mm; Exducer 58.8mm, Blades 12
TD06SL2= Inducer 61mm; Exducer 54.1mm, Blades 11
Like i said above i would suggest a TD05SH-18G (T518Z), the SR guys are seeing slightly better response than a GT2871R (20psi~3500rpm) and they make 260kw+ with cams (on an SR).
Edited by D_Stirls
If your willing to be clever, you can get a "T518Z" from kando for 700 bucks. TD05H-18G in an SR20 bolt on form (internal gate) which is the trust style item. As mentioned above, strong results on SR's. I dont think you would need a 10cm housing for the said unit, however the clever part is what you will do about it being T2 based. See if that dudes RB20 with bolt on adapter works out and that will tell you if this combo will also work. That would meet and exceed what you are describing above.
However, be it myself I would probably look to work with what ive got.. If its an RB20 turbo you should be able to go to a R33 2IU rear housing for a MINOR increase in AR. Pick up a dud housing and have HG grind it out to the right size for you. Thats likely to be what I would do, that or an OP6 rear housing with your existing working unit.
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
