Swapped my rear housing to a 10cm, made 235kw on 18psi. Was expecting more, and the Stagea needs more being a big heavy car.
Mick had to put a shim in the turbosmart gate to stiffen the spring, as it didn't want to hold boost. You can see it peaks at 18-19psi and then tapers down rather quickly. Rubbish, my old tial off the skyline held boost rock solid.
Turbo didn't want to make any more power either apparently, which is pretty lame.
Specs:
Kando TD06H 10cm
Turbosmart comp gate (f**king rubish unit, never using it again!)
3 inch exhaust
return flow intercooler
high flow injectors
Haltech E11
Run in RWD
98 Octane
I guess I'll go a T67 next, or probably back to Garret. See what happens. Unless someone can suggest something good for 280-300kw? needs to be low mount though for uber stealth.
Adam I reckon its the return flow cooler. Those always cause havoc..
The turbo should make plenty more than that, especially with the H rear side. I'm assuming its a 20G compressor? 260+ should be more like it.
The fact the tuner thinks the turbo is running out of puff definitely tells me the restriction is in the intake side.
After seen Roy mentioning about the TD06H I went through all TD06H dyno readings on Trent's dyno and did comparison against the SL2 turbine. TD06H turbine appeared to be laggier without making any more power. You can try our billet SS2 comped SL2s that is a step up from the standard 20Gs, or I think a standard highflowed turbo would make more power.
depending on where the external gate is attached. won't make good results if it is welded on turbine housing, locating it to exhaust manifold would prove other wise.
Cheap return flow cooler do have heatsoaking issue and takes much longer to heat sink compare to a good branded cooler.
^^ This, if done right.
All Stao's attempts have been at 90 degrees to the flow I think, mine (Artz's) had a nicely die ground entry knife edge with a curved pipe. There is no way the exhaust flow can do a 90 degree bend while travelling at the speed of sound...
My thoughts exactly regarding what it "should" make. Interesting idea on the return flow cooler setup.
I like how the engine bay looks nearly stock (except the gate off the manifold). But if going the conventional intercooler setup to gain a extra 30-40kw then I'd be down for that.
Though pin-pointing whether it is the cooler setup holding it back, or if I just got a odd turbo or whatever, will be the tricky part.
Just don't buy a "conventional" setup the same as you sold me...what a piece of shit..i fixed it, but what a piece of shit...lol
intercooler pipes didn't line up, not enough silicon, the intecooler pipe mount that goes at top of rockers was complety wrong..lol
cheers
darren
Edited by jet_r31
I'm not using a justjap kit, we made our own using a core with inlet/outlet on the one side.
But still, kinda don't want to spend any more money on it until I know for certian, this whole kando ordeal I've had ... I probably could of bought a 3076 or something with the cash wasted :(
I'll do some digging on the return flow cooler problems though while I'm at it, anyone else had problems with return flow intercoolers?
cheers
darren
I sold you a intercooler kit? was it brand new? if so you might want to talk to Darren Spencer (as that's who I got it from) about it, he had been importing them and assured they'd be a good fit.
Edited by Run-It-Hard
yep, new, ..worst china cooler kit i have ever seen, f**king pos...if you paid a workshop to fit
it would cost a f**king fortune , absolute mongoloid...not angry at you, just telling you, if you go conventional..do NOT buy another one..lol
i just put a 38mm turbodumb gate on my hypergear G3 turbo of exhaust housing, straight 90 right at the flange, in a stagea has to be close as it ends up to near to the strut tower for my liking, and i am not really sure making it a nice entry makes any difference, i would want to see the results backed to back to worry about piss farting around with it(for this car anyway) . I also woudn't be suprised
if using different brands of gates made a big difference aswell
cheers
darren
Edited by jet_r31
My brothers car had the same problem low power reading cause the return flow cooler setup on his car
He went thru numerous turbo setups all came up short of what they should put out and got his cams dialed in still similar results
End up just changing the cooler to a normal cheap 3inch inlet opposite sides and bang 20kw should have done it to start
Unigroup told him to change the cooler at the start but he didn't want to butcher the battery tray as it was a 180sx they did all the usual tests pressure drop,exhaust back pressure and comp test all came up good
yep ^
I think its more so the harsh turn that the air has to do in order to flow back the way it came which causes friction to the air's particles and super heats the charge after its already been through the cooler.
You then have a nice cap on how much power you can actually make, and theres no way you can test it as pressure drops and air leaks have little to do with it. The core Adam is describing is the worst, where it basically hits a brick wall and is forced back the other way.
I know the air particles business sounds airy fairy star wars but thats actually the way it works. air gets friction against itself and gets hotter.
This is the kinda core I'm using lads. I get where your coming from Scott. I guess I need to decide whether I want the car to look stock and have average power, or put in a conventional cooler kit and gain the missing power I should have, if thats the problem.
Another thing Mick mentioned is that the turbo didn't want to make any more boost, maybe the intercooler is a restriction after all. I think I'll sort it out after Eastern creek next week.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
